I started with the default, that clients could change their own settings.
And also in the beginning of the installation file (UrBackup Client 2.3.4.exe) comes this after the installation wizard that I can choose which drives and so on. In this moment the client does not know the server settings (e.g. that he is not allowed to change settings and makes his own).
Now I disabled the abilitiy to make their own settings with: Allow client-side changing of settings: (off)
and Allow client-side changing of the directories to backup: (off).
But it didnt work somehow. I reinstalled also with the UrBackup Client 2.3.4(x64).msi from the download page, but that was somehow weird. Didnt gave the settings option where I can choose if system drive and which kind of files and it made no real program in my program list when pressing the windows key in windows 10 1803 (is this already to old? it says only up to date windows version)
So I used the .exe.
I found that if I “cancel” this “what do you want do backup” after the install wizard I can make that the client has no settings.
Then I wait a while and the client and server are starting to communicate.
Is there a way without reinstalling and canceling the installation process to FORCE global settings and completely ignore client settings?
Otherwise I have to touch every client again. Maybe I understand something wrong.
But as far as I saw it the client settings won over the global settings, even if I disallow the change of client settings. Change does not mean no settings only that the settings before could not be changed anymore, right? Shouldnt it be: ignore client settings and force global server settings or specific client settings but from server side?
2019-02-13 11:41:50: rc=0 hasError=true state=0
2019-02-13 11:41:52: ClientService cmd: STATUS DETAIL#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 11:41:53: ClientService cmd: STATUS DETAIL#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 11:41:54: ClientService cmd: STATUS DETAIL#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 11:41:55: rc=0 hasError=true state=0
2019-02-13 11:41:57: ClientService cmd: STATUS DETAIL#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 11:41:57: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 11:41:58: ClientService cmd: STATUS DETAIL#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 11:41:58: rc=0 hasError=true state=0
2019-02-13 11:42:03: ClientService cmd: #I605KHhQmvB0tVES8nWnv#3START FULL BACKUP group=0&running_jobs=1&sha=528&with_permissions=1&with_scripts=1&with_orig_path=1&with_sequence=1&with_proper_symlinks=1&status_id=13&async=1#token=zUgdfHWWo8uJKNlhz25p
2019-02-13 11:42:03: Async index aac0f796591cae59964cb3ac0b90d6ec
2019-02-13 11:42:03: Removing VSS log data...
2019-02-13 11:42:03: ClientService cmd: #I605KHhQmvB0tVES8nWnv#2PING RUNNING pc_done=&eta_ms=5155571&status_id=13&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=zUgdfHWWo8uJKNlhz25p
2019-02-13 11:42:03: Final path: C:\
2019-02-13 11:42:03: Final path: D:\
2019-02-13 11:42:03: ERROR: Could not open path in os_get_final_path for "E:\"
2019-02-13 11:42:03: Final path: E:\
2019-02-13 11:42:03: ERROR: Could not open path in os_get_final_path for "F:\"
2019-02-13 11:42:03: Final path: F:\
2019-02-13 11:42:03: Script list at "C:\Program Files\UrBackup\backup_scripts\list.bat" does not exist. Skipping.
2019-02-13 11:42:03: Deleting files... doing full index...
2019-02-13 11:42:03: rc=0 hasError=true state=0
2019-02-13 11:42:03: ClientService cmd: #I605KHhQmvB0tVES8nWnv#WAIT FOR INDEX async_id=aac0f796591cae59964cb3ac0b90d6ec#token=zUgdfHWWo8uJKNlhz25p
2019-02-13 11:42:03: Wait for async index aac0f796591cae59964cb3ac0b90d6ec
2019-02-13 11:42:03: Removing deleted directories from index...
2019-02-13 11:42:03: Creating shadowcopy of "C" in indexDirs()
2019-02-13 11:42:03: WARNING: Restarting shadow copy of C:\ because it was started by this server
2019-02-13 11:42:03: Releasing C: orig_target=C: target=\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\
2019-02-13 11:42:03: Deleting shadowcopy for path "\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy3\" -2
2019-02-13 11:42:04: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 11:42:05: Number of Writers: 11
2019-02-13 11:42:05: Writer Task Scheduler Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer VSS Metadata Store Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer Performance Counters Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer System Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer BITS Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer MSSearch Service Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer ASR Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer WMI Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer Shadow Copy Optimization Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer Registry Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Writer COM+ REGDB Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:05: Deleting Shadowcopy for dir "C:\"
2019-02-13 11:42:07: Number of Writers: 11
2019-02-13 11:42:07: Writer Task Scheduler Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer VSS Metadata Store Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer Performance Counters Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer System Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer ASR Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer WMI Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer Registry Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer Shadow Copy Optimization Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer BITS Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer MSSearch Service Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Writer COM+ REGDB Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:07: Preparing change block tracking reset for volume c: failed: Unzulässige Funktion. (code: 1)
2019-02-13 11:42:08: Number of Writers: 11
2019-02-13 11:42:08: Writer Task Scheduler Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer VSS Metadata Store Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer Performance Counters Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer System Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer ASR Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer WMI Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer Registry Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer Shadow Copy Optimization Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer BITS Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer MSSearch Service Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:08: Writer COM+ REGDB Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:10: Number of Writers: 11
2019-02-13 11:42:10: Writer Task Scheduler Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:10: Writer VSS Metadata Store Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:10: Writer Performance Counters Writer has failure state VSS_WS_STABLE with error S_OK.
2019-02-13 11:42:10: Writer System Writer has failure state VSS_WS_WAITING_FOR_BACKUP_COMPLETE with error S_OK.
2019-02-13 11:42:10: Writer ASR Writer has failure state VSS_WS_WAITING_FOR_BACKUP_COMPLETE with error S_OK.
2019-02-13 11:42:10: Writer WMI Writer has failure state VSS_WS_WAITING_FOR_BACKUP_COMPLETE with error S_OK.
2019-02-13 11:42:10: Writer Registry Writer has failure state VSS_WS_WAITING_FOR_BACKUP_COMPLETE with error S_OK.
2019-02-13 11:42:10: Writer Shadow Copy Optimization Writer has failure state VSS_WS_WAITING_FOR_BACKUP_COMPLETE with error S_OK.
2019-02-13 11:42:10: Writer BITS Writer has failure state VSS_WS_WAITING_FOR_BACKUP_COMPLETE with error S_OK.
2019-02-13 11:42:10: Writer MSSearch Service Writer has failure state VSS_WS_WAITING_FOR_BACKUP_COMPLETE with error S_OK.
2019-02-13 11:42:10: Writer COM+ REGDB Writer has failure state VSS_WS_WAITING_FOR_BACKUP_COMPLETE with error S_OK.
2019-02-13 11:42:10: Shadowcopy path: \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4
2019-02-13 11:42:10: done.
2019-02-13 11:42:10: Disabling CBT on volume "C:"
2019-02-13 11:42:10: Changed dir: c:\program files (x86)\gigabyte\smart timelock\
2019-02-13 11:42:10: Changed dir: c:\program files (x86)\teamviewer\
2019-02-13 11:42:10: Changed dir: c:\program files\urbackup\
2019-02-13 11:42:10: Changed dir: c:\program files\urbackup\urbackup\
2019-02-13 11:42:10: Changed dir: c:\program files\urbackup\urbackup\data\
2019-02-13 11:42:10: Changed dir: c:\programdata\adobe\
2019-02-13 11:42:10: Changed dir: c:\programdata\adobe\arm\
2019-02-13 11:42:10: Changed dir: c:\programdata\adobe\arm\s\
2019-02-13 11:42:10: Changed dir: c:\programdata\adobe\arm\{291aa914-a987-4ce9-bd63-ac0a92d435e5}\
2019-02-13 11:42:10: Changed dir: c:\programdata\microsoft\diagnosis\
2019-02-13 11:42:10: Changed dir: c:\programdata\microsoft\network\downloader\
2019-02-13 11:42:10: Changed dir: c:\programdata\microsoft\search\data\applications\windows\gatherlogs\systemindex\
2019-02-13 11:42:10: Changed dir: c:\programdata\microsoft\windows defender\definition updates\{fbb1b66d-26c5-4319-96fa-9ad43a6d234f}\
2019-02-13 11:42:10: Changed dir: c:\programdata\microsoft\windows defender\scans\
2019-02-13 11:42:10: Changed dir: c:\programdata\microsoft\windows defender\support\
2019-02-13 11:42:10: Changed dir: c:\programdata\microsoft\windows security health\logs\
2019-02-13 11:42:10: Changed dir: c:\programdata\microsoft\windows\wfp\
2019-02-13 11:42:10: Changed dir: c:\programdata\nvidia corporation\nvtelemetry\
2019-02-13 11:42:10: Changed dir: c:\programdata\packages\appleinc.itunes_nzyj5cx40ttqa\s-1-5-21-260802115-3076140393-2772627985-1001\systemappdata\helium\
2019-02-13 11:42:10: Changed dir: c:\programdata\packages\appleinc.itunes_nzyj5cx40ttqa\s-1-5-21-260802115-3076140393-2772627985-1001\systemappdata\helium\cache\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\connecteddevicesplatform\672494e47990aaf0\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\google\chrome\user data\profile 1\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\google\chrome\user data\profile 1\cache\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\google\chrome\user data\profile 1\extension state\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\google\chrome\user data\profile 1\gpucache\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\google\chrome\user data\profile 1\local storage\leveldb\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\google\chrome\user data\shadercache\gpucache\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\microsoft\onedrive\logs\common\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\microsoft\onedrive\logs\personal\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\microsoft\windows\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\microsoft\windows\explorer\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\microsoft\windows\notifications\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\microsoft\windows\webcache\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\packages\inputapp_cw5n1h2txyewy\settings\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\packages\microsoft.windows.cortana_cw5n1h2txyewy\settings\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\packages\microsoft.windows.shellexperiencehost_cw5n1h2txyewy\settings\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\local\temp\
2019-02-13 11:42:10: Changed dir: c:\users\marvin\appdata\locallow\microsoft\cryptneturlcache\metadata\
2019-02-13 11:42:10: Changed dir: c:\windows\appcompat\programs\
2019-02-13 11:42:10: Changed dir: c:\windows\logs\windowsupdate\
2019-02-13 11:42:10: Changed dir: c:\windows\prefetch\
2019-02-13 11:42:10: Changed dir: c:\windows\serviceprofiles\localservice\
2019-02-13 11:42:10: Changed dir: c:\windows\serviceprofiles\networkservice\
2019-02-13 11:42:10: Changed dir: c:\windows\serviceprofiles\networkservice\appdata\local\microsoft\windows\deliveryoptimization\logs\
2019-02-13 11:42:10: Changed dir: c:\windows\serviceprofiles\networkservice\appdata\local\microsoft\windows\deliveryoptimization\state\
2019-02-13 11:42:10: Changed dir: c:\windows\softwaredistribution\
2019-02-13 11:42:10: Changed dir: c:\windows\softwaredistribution\datastore\
2019-02-13 11:42:10: Changed dir: c:\windows\softwaredistribution\datastore\logs\
2019-02-13 11:42:10: Changed dir: c:\windows\system32\config\
2019-02-13 11:42:10: Changed dir: c:\windows\system32\logfiles\wmi\
2019-02-13 11:42:10: Changed dir: c:\windows\system32\wbem\repository\
2019-02-13 11:42:10: Changed dir: c:\windows\system32\winevt\logs\
2019-02-13 11:42:10: Changed dir: c:\windows\temp\
2019-02-13 11:42:10: Indexing "C"...
2019-02-13 11:42:10: Not following symlink "C:\Programme" because symlink target at "C:\Program Files" is excluded
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\TabTip.exe to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\TipRes.dll to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\tabskb.dll to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\tipresx.dll to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\tipskins.dll to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\tiptsf.dll to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\LanguageModel\chstic.dgml to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\de-DE\TabTip.exe.mui to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\de-DE\TipRes.dll.mui to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\de-DE\TipTsf.dll.mui to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\de-DE\tabskb.dll.mui to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\de-DE\tipresx.dll.mui to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\en-us\boxed-correct.avi to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\en-us\boxed-delete.avi to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\en-us\boxed-join.avi to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\en-us\boxed-split.avi to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\en-us\correct.avi to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\en-us\delete.avi to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\en-us\join.avi to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\en-us\split.avi to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\fsdefinitions\auxpad.xml to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\fsdefinitions\insert.xml to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\fsdefinitions\keypad.xml to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\fsdefinitions\main.xml to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\fsdefinitions\oskclearui.xml to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\fsdefinitions\oskmenu.xml to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
2019-02-13 11:42:12: ERROR: Cannot open file \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy4\Mount\Program Files\Common Files\Microsoft Shared\ink\fsdefinitions\osknav.xml to read the FRN. Das System kann auf die Datei nicht zugreifen. (code: 1920)
Unfortunately, this does not show the settings exchange. Could you stop the client service, wait 5min (for it to go offline on the server web interface), then start it again? Then post the log after ~2min. Thanks!
But my Default Path is now:
C:|C/optional;D:|D/optional;E:|E/optional;E:|E/optional
Just to not get the backup process error for that reason I switched drive letter E to another one on my PC (Drive Letter E was before a DVD Drive).
Restarting server now completely and windows PC, too.
I am having the following exclusion list: C:\WINDOWS\system32\LogFiles\WMI\RtBackup\:.:;C:\Users\:\index.dat;C:\WINDOWS\Minidump\*;:\Pagefile.sys;C:\WINDOWS\system32\MSDtc\MSDTC.LOG;C:\WINDOWS\netlogon.chg;:\hiberfil.sys;:\System Volume Information\*;C:\ProgramData\Microsoft\Windows\WER\*;C:\WINDOWS\softwaredistribution\*.*;C:\ProgramData\Microsoft\Network\Downloader\:;C:\WINDOWS\CSC\*;C:\WINDOWS\System32\Bits.log;C:\WINDOWS\System32\Bits.bak;C:\Users\:\AppData\Local\Temp;C:\Users\:\AppData\Local\Microsoft\Windows\Temporary Internet Files;C:\Users\:\AppData\Local\Google\Chrome\User Data\Default\Cache;C:\Users\:\AppData\Local\Google\Chrome\User Data\Default\Media Cache;C:\Users\:\AppData\Local\Microsoft\Windows\Explorer\thumbcache*;C:\Users\:\AppData\Local\Mozilla\Firefox\Profiles\:\cache2;C:\Users\:\AppData\Local\Mozilla\Firefox\Profiles\:\cache;C:\Windows\Temp;:\$Recycle.Bin;:\System Volume Information;C:\Windows.old;C:\Windows;C:\Program Files;C:\Program Files (x86);C:\ProgramData;*\Nextcloud\*;*\OneDrive\*;*\OneDriveTemp\*;*\AppData\Local\Microsoft\WindowsApps\**;*\AppData\Local\Packages\*;:\$Windows.~BT;*\AdwCleaner\FileQuarantine\*;*\AdwCleaner\RegistryQuarantine\*;*\AdwCleaner\Quarantine\*
Should I add *\HarddiskVolumeShadowCopy* to the exclusion?
restarted everything, now this came (have the client from webgui installed [before] and have Windows 1809, thought maybe this will repair windows errors):
Windows components backup configuration is set to “Default=0”
2019-02-13 13:51:51: Loaded -fileserv- plugin
2019-02-13 13:51:51: Loaded -fsimageplugin- plugin
2019-02-13 13:51:51: Loaded -cryptoplugin- plugin
2019-02-13 13:51:51: SQLite: recovered 414 frames from WAL file C:\Program Files\UrBackup\urbackup\backup_client.db-wal code: 283
2019-02-13 13:51:51: urbackupserver: Server started up successfully!
2019-02-13 13:51:51: Started UrBackupClient Backend...
2019-02-13 13:51:51: FileSrv: Backup privileges set successfully
2019-02-13 13:51:51: FileSrv: Backup privileges set successfully (SE_SECURITY_NAME)
2019-02-13 13:51:51: FileSrv: Backup privileges set successfully (SE_RESTORE_NAME)
2019-02-13 13:51:51: FileSrv: Binding UDP socket at port 35622...
2019-02-13 13:51:51: FileSrv: done.
2019-02-13 13:51:51: FileSrv: Disabling new behavior...
2019-02-13 13:51:51: FileSrv: Servername: -Marvins-PC-
2019-02-13 13:51:51: FileSrv: Server started up successfully
2019-02-13 13:51:51: Filesystem. Vol="\\?\Volume{abd0355c-e675-11e3-be66-806e6f6e6963}\" Name="system-reserviert" Type="ntfs" VPaths=0 Size=366997504
2019-02-13 13:51:51: Bootable flag set for volume
2019-02-13 13:51:51: Found potential candidate: \\?\Volume{abd0355c-e675-11e3-be66-806e6f6e6963}\ Score: 103
2019-02-13 13:51:51: Filesystem. Vol="\\?\Volume{b05cc016-2ee9-47c8-935a-2860d5439466}\" Name="hdd speicher" Type="ntfs" VPaths=1 Size=1000068870144
2019-02-13 13:51:51: GPT formated hard disk encountered. No bootable flag. Attributes = 0
2019-02-13 13:51:51: Bootable flag not set for volume
2019-02-13 13:51:51: Filesystem. Vol="\\?\Volume{abd0355d-e675-11e3-be66-806e6f6e6963}\" Name="ssd system" Type="ntfs" VPaths=1 Size=236293451776
2019-02-13 13:51:51: Filesystem is System partition. Skipping...
2019-02-13 13:51:51: Filesystem. Vol="\\?\Volume{c452fa8b-0000-0000-0000-201a37000000}\" Name="" Type="ntfs" VPaths=0 Size=893382656
2019-02-13 13:51:51: Found potential candidate: \\?\Volume{c452fa8b-0000-0000-0000-201a37000000}\ Score: 1
2019-02-13 13:51:51: FileSrv: UDP Thread startet
2019-02-13 13:51:51: Filesystem. Vol="\\?\Volume{e0a5330a-125d-11e8-83ca-806e6f6e6963}\" Name="" Type="" VPaths=1 Size=-1
2019-02-13 13:51:51: GetVolumeInformation failed with error code 21. Skipping...
2019-02-13 13:51:51: Selected volume \\?\Volume{abd0355c-e675-11e3-be66-806e6f6e6963}
2019-02-13 13:51:51: System dir: C:\WINDOWS
2019-02-13 13:51:51: Volpath: \\.\C:
2019-02-13 13:51:51: Device is not GPT formatted (0)
2019-02-13 13:51:51: Found no EFI System Partition
2019-02-13 13:51:52: Internet mode not enabled
2019-02-13 13:51:52: Looking for old Sessions... 0 sessions
2019-02-13 13:51:58: Final path: C:\
2019-02-13 13:51:58: Final path: D:\
2019-02-13 13:51:58: ERROR: Could not open path in os_get_final_path for "E:\"
2019-02-13 13:51:58: Final path: E:\
2019-02-13 13:51:58: Persisted open files list is obsolete (restart occurred) (1)
2019-02-13 13:51:59: WARNING: There are 1832184 new USN entries at 'c:' - reindexing
2019-02-13 13:51:59: Deleting directory FRN info from database...
2019-02-13 13:51:59: Deleting saved journal data from database...
2019-02-13 13:51:59: Starting indexing process..
2019-02-13 13:52:03: Added 69016 directory FRNs to temporary database...
2019-02-13 13:52:03: MFT has 359272 FRNs.
2019-02-13 13:52:03: Copying directory FRNs to database...
2019-02-13 13:52:03: Dropping temporary database...
2019-02-13 13:52:03: Saving new journal data to database. Forcing update...
2019-02-13 13:52:03: Setting indexing to done for c:
2019-02-13 13:52:03: Reindexing of 'c:' done.
2019-02-13 13:52:03: ERROR: GetVolumePathName(dir, volume_path, MAX_PATH) failed in ChangeJournalWatcher::watchDir for dir e:\
2019-02-13 13:52:12: urbackupserver: No available slots... starting new Worker
2019-02-13 13:52:12: ClientService cmd: FSTATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 13:52:13: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 13:53:03: ClientService cmd: #IHvIc7ZKYf4n4h3Rpgy7M#ADD IDENTITY
2019-02-13 13:53:03: rc=0 hasError=true state=0
2019-02-13 13:53:03: ClientService cmd: #IHvIc7ZKYf4n4h3Rpgy7M#GET CHALLENGE
2019-02-13 13:53:03: ClientService cmd: #IHvIc7ZKYf4n4h3Rpgy7M#SIGNATURE#pubkey=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--&pubkey_ecdsa409k1=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--&signature=AA0//HjIDtE+JEVGK6gR553EU0NzczxgG8kg7L99n8a1R/j4wafnIQ--&signature_ecdsa409k1=bmwXiRWxN3eeHRat4JQaNiNcx4s7elNV3/2CR1yisNleLx8rSw1k0qgDvGbUYnDY3s3THEG5YvLL6rp7dGrnIiXbaRbclPqcYKgzRjBYFt0ySO2CucK/wYPOoXpENd0j9x+EeGZe&session_identity=dwkzcHXC6UME7tNPkNbX
2019-02-13 13:53:03: ClientService cmd: #IdwkzcHXC6UME7tNPkNbX#CAPA
2019-02-13 13:53:04: Cannot read data from device (L:\)
2019-02-13 13:53:04: Device L:\ isn't NTFS formatted
2019-02-13 13:53:04: rc=0 hasError=true state=0
2019-02-13 13:53:04: ClientService cmd: #IdwkzcHXC6UME7tNPkNbX#1CHANNEL capa=55315&token=zUgdfHWWo8uJKNlhz25p&restore_version=1&virtual_client=
2019-02-13 13:53:04: New channel: Number of Channels: 1
2019-02-13 13:53:04: ClientService cmd: #IdwkzcHXC6UME7tNPkNbX#SETTINGS update_freq_incr=86400
update_freq_incr_def=86400
update_freq_full=2592000
update_freq_full_def=2592000
update_freq_image_full=5184000
update_freq_image_full_def=5184000
update_freq_image_incr=604800
update_freq_image_incr_def=604800
max_file_incr=2
max_file_incr_def=2
min_file_incr=1
min_file_incr_def=1
max_file_full=2
max_file_full_def=2
min_file_full=1
min_file_full_def=1
min_image_incr=1
min_image_incr_def=1
max_image_incr=2
max_image_incr_def=2
min_image_full=1
min_image_full_def=1
max_image_full=2
max_image_full_def=2
startup_backup_delay=60
startup_backup_delay_def=60
backup_window_incr_file=1-7/6:01-21:59
backup_window_incr_file_def=1-7/6:01-21:59
backup_window_full_file=1-7/6:01-21:59
backup_window_full_file_def=1-7/6:01-21:59
backup_window_incr_image=1-7/6:01-21:59
backup_window_incr_image_def=1-7/6:01-21:59
backup_window_full_image=1-7/6:01-21:59
backup_window_full_image_def=1-7/6:01-21:59
exclude_files=C:\WINDOWS\system32\LogFiles\WMI\RtBackup\:.:;C:\Users\:\index.dat;C:\WINDOWS\Minidump\*;:\Pagefile.sys;C:\WINDOWS\system32\MSDtc\MSDTC.LOG;C:\WINDOWS\netlogon.chg;:\hiberfil.sys;:\System Volume Information\*;C:\ProgramData\Microsoft\Windows\WER\*;C:\WINDOWS\softwaredistribution\*.*;C:\ProgramData\Microsoft\Network\Downloader\:;C:\WINDOWS\CSC\*;C:\WINDOWS\System32\Bits.log;C:\WINDOWS\System32\Bits.bak;C:\Users\:\AppData\Local\Temp;C:\Users\:\AppData\Local\Microsoft\Windows\Temporary Internet Files;C:\Users\:\AppData\Local\Google\Chrome\User Data\Default\Cache;C:\Users\:\AppData\Local\Google\Chrome\User Data\Default\Media Cache;C:\Users\:\AppData\Local\Microsoft\Windows\Explorer\thumbcache*;C:\Users\:\AppData\Local\Mozilla\Firefox\Profiles\:\cache2;C:\Users\:\AppData\Local\Mozilla\Firefox\Profiles\:\cache;C:\Windows\Temp;:\$$Recycle.Bin;:\System Volume Information;C:\Windows.old;C:\Windows;C:\Program Files;C:\Program Files (x86);C:\ProgramData;*\Nextcloud\*;*\OneDrive\*;*\OneDriveTemp\*;*\AppData\Local\Microsoft\WindowsApps\**;*\AppData\Local\Packages\*;:\$$Windows.~BT;*\AdwCleaner\FileQuarantine\*;*\AdwCleaner\RegistryQuarantine\*;*\AdwCleaner\Quarantine\*
exclude_files_def=C:\WINDOWS\system32\LogFiles\WMI\RtBackup\:.:;C:\Users\:\index.dat;C:\WINDOWS\Minidump\*;:\Pagefile.sys;C:\WINDOWS\system32\MSDtc\MSDTC.LOG;C:\WINDOWS\netlogon.chg;:\hiberfil.sys;:\System Volume Information\*;C:\ProgramData\Microsoft\Windows\WER\*;C:\WINDOWS\softwaredistribution\*.*;C:\ProgramData\Microsoft\Network\Downloader\:;C:\WINDOWS\CSC\*;C:\WINDOWS\System32\Bits.log;C:\WINDOWS\System32\Bits.bak;C:\Users\:\AppData\Local\Temp;C:\Users\:\AppData\Local\Microsoft\Windows\Temporary Internet Files;C:\Users\:\AppData\Local\Google\Chrome\User Data\Default\Cache;C:\Users\:\AppData\Local\Google\Chrome\User Data\Default\Media Cache;C:\Users\:\AppData\Local\Microsoft\Windows\Explorer\thumbcache*;C:\Users\:\AppData\Local\Mozilla\Firefox\Profiles\:\cache2;C:\Users\:\AppData\Local\Mozilla\Firefox\Profiles\:\cache;C:\Windows\Temp;:\$$Recycle.Bin;:\System Volume Information;C:\Windows.old;C:\Windows;C:\Program Files;C:\Program Files (x86);C:\ProgramData;*\Nextcloud\*;*\OneDrive\*;*\OneDriveTemp\*;*\AppData\Local\Microsoft\WindowsApps\**;*\AppData\Local\Packages\*;:\$$Windows.~BT;*\AdwCleaner\FileQuarantine\*;*\AdwCleaner\RegistryQuarantine\*;*\AdwCleaner\Quarantine\*
include_files=
include_files_def=
default_dirs=C:\|C/optional;D:\|D/optional;E:\|E/optional;E:\|E/optional
default_dirs_def=C:\|C/optional;D:\|D/optional;E:\|E/optional;E:\|E/optional
allow_config_paths=false
allow_config_paths_def=false
allow_starting_full_file_backups=true
allow_starting_full_file_backups_def=true
allow_starting_incr_file_backups=true
allow_starting_incr_file_backups_def=true
allow_starting_full_image_backups=true
allow_starting_full_image_backups_def=true
allow_starting_incr_image_backups=true
allow_starting_incr_image_backups_def=true
allow_pause=false
allow_pause_def=false
allow_log_view=true
allow_log_view_def=true
allow_overwrite=false
allow_overwrite_def=false
allow_tray_exit=false
allow_tray_exit_def=false
image_letters=C
image_letters_def=C
internet_server=
internet_server_def=
internet_server_port=55415
internet_server_port_def=55415
internet_authkey=DNsQYgfquU
internet_authkey_def=DNsQYgfquU
internet_speed=0
internet_speed_def=0
local_speed=0
local_speed_def=0
internet_image_backups=false
internet_image_backups_def=false
internet_full_file_backups=false
internet_full_file_backups_def=false
internet_encrypt=true
internet_encrypt_def=true
internet_compress=true
internet_compress_def=true
internet_mode_enabled=false
internet_mode_enabled_def=false
silent_update=true
silent_update_def=true
client_quota=
client_quota_def=
local_full_file_transfer_mode=hashed
local_full_file_transfer_mode_def=hashed
internet_full_file_transfer_mode=raw
internet_full_file_transfer_mode_def=raw
local_incr_file_transfer_mode=hashed
local_incr_file_transfer_mode_def=hashed
internet_incr_file_transfer_mode=blockhash
internet_incr_file_transfer_mode_def=blockhash
local_image_transfer_mode=hashed
local_image_transfer_mode_def=hashed
internet_image_transfer_mode=raw
internet_image_transfer_mode_def=raw
end_to_end_file_backup_verification=false
end_to_end_file_backup_verification_def=false
internet_calculate_filehashes_on_client=true
internet_calculate_filehashes_on_client_def=true
internet_parallel_file_hashing=false
internet_parallel_file_hashing_def=false
image_file_format=vhdz
image_file_format_def=vhdz
internet_connect_always=false
internet_connect_always_def=false
server_url=http://192.168.2.22:55414
server_url_def=http://192.168.2.22:55414
verify_using_client_hashes=false
verify_using_client_hashes_def=false
internet_readd_file_entries=true
internet_readd_file_entries_def=true
background_backups=true
background_backups_def=true
local_incr_image_style=to-full
local_incr_image_style_def=to-full
local_full_image_style=full
local_full_image_style_def=full
internet_incr_image_style=to-last
internet_incr_image_style_def=to-last
internet_full_image_style=synthetic
internet_full_image_style_def=synthetic
create_linked_user_views=false
create_linked_user_views_def=false
max_running_jobs_per_client=1
max_running_jobs_per_client_def=1
cbt_volumes=ALL
cbt_volumes_def=ALL
cbt_crash_persistent_volumes=-
cbt_crash_persistent_volumes_def=-
ignore_disk_errors=false
ignore_disk_errors_def=false
vss_select_components=default=0
vss_select_components_def=default=0
allow_file_restore=true
allow_file_restore_def=true
allow_component_restore=false
allow_component_restore_def=false
allow_component_config=false
allow_component_config_def=false
file_snapshot_groups=
file_snapshot_groups_def=
image_snapshot_groups=
image_snapshot_groups_def=
internet_file_dataplan_limit=1048576000
internet_file_dataplan_limit_def=1048576000
internet_image_dataplan_limit=2097152000
internet_image_dataplan_limit_def=2097152000
alert_script=1
alert_script_def=1
alert_params=
alert_params_def=
2019-02-13 13:53:04: ERROR: Could not open path in os_get_final_path for "E:\"
2019-02-13 13:53:04: ClientService cmd: #IdwkzcHXC6UME7tNPkNbX#INCRINTERVALL "259203?startup_delay=60"
2019-02-13 13:53:04: ClientService cmd: #IdwkzcHXC6UME7tNPkNbX#VERSION 224
2019-02-13 13:53:04: Server has new version 224 (client version: 0). Updating...
2019-02-13 13:53:04: Not down-grading from current client version 225 to server version 224
2019-02-13 13:53:04: Internet mode not enabled
2019-02-13 13:53:05: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 13:53:11: FileSrv: Stopping CUPDThread...
2019-02-13 13:53:23: ERROR: Recvfrom error in CUDPThread::UdpStep
2019-02-13 13:53:23: ERROR: Last error: 10058
2019-02-13 13:53:23: CUDPThread exited.
2019-02-13 13:53:23: FileSrv: Backup privileges set successfully
2019-02-13 13:53:23: FileSrv: Backup privileges set successfully (SE_SECURITY_NAME)
2019-02-13 13:53:23: FileSrv: Backup privileges set successfully (SE_RESTORE_NAME)
2019-02-13 13:53:23: Final path: C:\
2019-02-13 13:53:23: FileSrv: Binding UDP socket at port 35622...
2019-02-13 13:53:23: FileSrv: done.
2019-02-13 13:53:23: FileSrv: Disabling new behavior...
2019-02-13 13:53:23: FileSrv: Servername: -Marvins-PC-
2019-02-13 13:53:23: FileSrv: Server started up successfully
2019-02-13 13:53:23: FileSrv: UDP Thread startet
2019-02-13 13:53:23: Final path: D:\
2019-02-13 13:53:23: ERROR: Could not open path in os_get_final_path for "E:\"
2019-02-13 13:53:23: Final path: E:\
2019-02-13 13:53:56: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 13:54:04: ClientService cmd: PONG
2019-02-13 13:54:48: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 13:54:52: Internet mode not enabled
2019-02-13 13:55:04: ClientService cmd: PONG
2019-02-13 13:55:40: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 13:56:04: ClientService cmd: PONG
2019-02-13 13:56:32: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 13:57:04: ClientService cmd: PONG
2019-02-13 13:57:23: ClientService cmd: STATUS#pw=DeCmGYDwtHcEOj3tCvwHUB1yxnVSO4
2019-02-13 13:58:04: ClientService cmd: PONG
I see no issue. The client uses the server settings. You can double-check if "C:\Program Files\UrBackup\urbackup\data\settings.cfg" lists the same exclude_files line as the log, but the probability is low that it doesn’t.
