I’m using the docker version of urbackup server and I’m very happy with it. I’d like to disable IPv6 support entirely on the server, since my local network is not using IPv6 and my logs are full of:
Yeah I had a similar problem with clients connecting over IPv6 and not syncing. All the info I could find suggested that you cannot disable IPv6 in the settings and you either have to disable it on the entire server or on the client (or both). If I’m wrong, please someone correct me.
Sorry you are having issues. To solve the problem the client (debug) log and/or a crash dump would be useful.
If possible, could you post it or send it?
