Recently my urbackup webinterface does not seem to be working. It loads but there is no way to enter the password.
I have done urbackupsrv restart
I have rebuilt the data base.
I rebooted the computer and the client computers.
There are not errors on the browser.
I tried http://192.168.1.65:55414/x?a=server_status and the browser just shows the word forbidden.
I can not get it to open the password dialog.
Here is my debug log during start up. Any suggestions what to do next?:
2019-11-19 21:56:02: Starting HTTP-Server on port 55414
2019-11-19 21:56:02: HTTP: Server started up successfully!
2019-11-19 21:56:02: SQLite: recovered 31 frames from WAL file /var/urbackup/backup_server.db-wal code: 283
2019-11-19 21:56:02: SQLite: recovered 265 frames from WAL file /var/urbackup/backup_server_files.db-wal code: 283
2019-11-19 21:56:02: SQLite: recovered 3 frames from WAL file /var/urbackup/backup_server_link_journal.db-wal code: 283
2019-11-19 21:56:02: SQLite: recovered 124 frames from WAL file /var/urbackup/backup_server_links.db-wal code: 283
2019-11-19 21:56:02: Started UrBackup…
2019-11-19 21:56:02: Removing temporary files…
2019-11-19 21:56:02: UrBackup Server start up complete.
2019-11-19 21:56:02: Server started up successfully!
2019-11-19 21:56:02: Looking for old Sessions… 0 sessions
2019-11-19 21:56:02: Recreating temporary folder…
2019-11-19 21:56:02: Downloading version file…
2019-11-19 21:56:03: Testing if backup destination can handle subvolumes and snapshots…
2019-11-19 21:56:03: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2019-11-19 21:56:03: Testing if backup destination can handle filesystem transactions…
2019-11-19 21:56:03: Testing for hardlinks in backup destination…
2019-11-19 21:56:03: Could create hardlink at backup destination. Hardlinks enabled.
2019-11-19 21:56:03: Testing for reflinks in backup destination…
2019-11-19 21:56:03: Reflink ioctl failed. errno=95
2019-11-19 21:56:03: Could not create reflink at backup destination. Reflinks disabled. Operation not supported (code: 95)
2019-11-19 21:56:03: Binding to interface enp63s0 for broadcasting…
2019-11-19 21:56:03: Broadcasting on interface IP 192.168.1.65
2019-11-19 21:56:03: Downloading version file…
2019-11-19 21:56:04: Downloading server version info…
2019-11-19 21:56:04: Downloading dataplan database…
