Removing backup dirs works:
$ urbackupclientctl remove-backupdir -n pgsql
$ urbackupclientctl list-backupdirs
No directories are being backed up
Adding backup dirs does not:
$ urbackupclientctl add-backupdir -n root --path / -x
$ echo $?
0
/var/log/urbackupclient.log with LOGLEVEL=debug in /etc/default/urbackupclient:
2023-11-24 19:55:37: ClientService cmd: SAVE BACKUP DIRS#pw=<stripped>&all_virtual_clients=1&enable_client_paths_use=1&dir_0=&dir_0_name=root/follow_symlinks,symlinks_optional,one_filesystem,share_hashes&dir_0_group=0
2023-11-24 19:55:37: rc=0 hasError=true state=0
As you can see, this contains hasError=true. This doesn’t seem to mean anything, because so does getting backup dirs which works fine:
2023-11-24 19:55:50: ClientService cmd: GET BACKUP DIRS#pw=<stripped>
2023-11-24 19:55:50: rc=0 hasError=true state=0
Versions used:
- UrBackup Client Controller v2.5.25.0
- UrBackup Client Backend v2.5.25.0
Tested on two clients.
Client auto-update is enabled on the server.
Server is on Infscape 1.11.3. I attempted to find out what UrBackup version that translates to, but the Infscape changelog (https://appupdate2.urbackup.org/amd64/production/changelog.pdf) does not mention this version…
@uroni May I provide straces in private?
