Hi All,
I’m trying to install UrBackup (v2.1.19) in a fresh Jail, on v11.0-U2, and am following the instructions laid out at: https://www.urbackup.org/freenasserverinstall.html , i.e.
pkg update
pkg install cryptopp
curl -O https://hndl.urbackup.org/Server/2.1.19/urbackup-server-2.1.19.tar.gz
tar xf urbackup-server-2.1.19.tar.gz
cd urbackup-server-2.1.19
./configure
make install -j4
But, I’m getting some errors and it fails to install after I use the make install -j4 command:
chown urbackup:urbackup “/usr/local/share/urbackup”
chown: urbackup: illegal group name
*** [install-data-local] Error code 1
make[2]: stopped in /urbackup-server-2.1.19
— install-exec-local —
pw useradd urbackup -q -g urbackup -d “/usr/local/var/urbackup” -m -s /usr/bin/false || true
chown urbackup:urbackup “/usr/local/var/urbackup”
1 error
*** [install-am] Error code 2
make[1]: stopped in /urbackup-server-2.1.19
1 error
*** [install-recursive] Error code 1
make: stopped in /urbackup-server-2.1.19
1 error
Anyone got any ideas?
Yours
Jonathan
So, I tried something different this time. After I ran pkg update and before I ran pkg install cryptopp, I did the following:
pw addgroup urbackup
(copying the useradd from the error output above)
Then I continued with the install, this time I don’t get any errors, but I’m unable to connect to it via 192.168.x.xxx:55414
Bah!
Yours
Jonathan
Is the UrBackup server service actually running?
Try urbackupsrv -v debug run
uroni
July 24, 2017, 12:18pm
4
Can someone confirm that user/groupadd needs to be changed on FreeBSD?
From
pw groupadd urbackup -q
to
pw addgroup urbackup -q
Hi Yes, seems I forgot to start the service /blush. All working now.
Must be something funny in the install script which stops user/group adding as expected.
Jonathan
uroni:
to
I just done a test, and both commands seem to work.
Jonathan
uroni
July 24, 2017, 12:25pm
7
Hmm, then the question is why it failed the first time…
Same here.
[root@freenas ~]# pw groupadd
pw: group name required
[root@freenas ~]# pw addgroup
[root@freenas ~]#
Thats 10.3-STABLE
Seems FreeBSD is more versatile than ever these days.
Maybe the group didn’t exist when chown was issued…
uroni
July 24, 2017, 12:29pm
10
So it has a delayed group creation feature
LOL. Who knows…
I just read the title for this thread again. I see he’s using v11. I’ve not taken the plunge yet.
Maybe it’s a bug.
mahi
January 25, 2019, 11:26am
12
@Hazimil I’m having same issue, coming up with many errors.
Do you have any guide how you did it…?
These are the issues I’m having.
I’ve been trying to install and configure Urbackup onto a FreeNAS FreeBSD server.
I’ve followed the instructions here as well as trying to follow the instructions here .
However, the first link gives me compile errors when I run:
$ make
$ make install
It returns C++ errors about the array being ambiguous. Switching urbackup version in the wget command to use the 2.1.19 package and that gets further, but errors about a byte.
The second one, we manage to get through the whole list of commands …
Hoping if someone have any idea how to solve this puzzel
Thank you
uroni
January 25, 2019, 11:42am
13
You just commited mass thread necromancy. It is unlikely your issue has anything to do with the issue in this thread (after 2 years…). If you do that again you will be permanently banned.
mahi
January 25, 2019, 11:54am
14
thanks for your reply, actully i was looking for information and couldn’t find anywhere .
and few post i found with similer issue. i didn’t meant to flood forum with my so many threads.
Cheerss
