Hi all,
I am having a issue backing up 2 VMs running Zimbra which have a sparse file that is blowing out the backup.
I think this issue is similar to this one: Sparse file replication size issue with the main difference being that I am on XFS.
I reviewed the patch linked but am running a client version that should contain the patch already but the backup size is 80GB and it is sending that much over the wire.
Looking for a bit of assistance if I’m doing something wrong or if this is a different manifestation due to XFS.
File is: /opt/zimbra/data/ldap/mdb/db/data.mdb
Backup Server:
[root@longwave /]# urbackupsrv --version
UrBackup Server v2.4.12.0
Copyright (C) 2011-2019 Martin Raiber
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
[root@longwave /]# xfs_info /tanbackups/
meta-data=/dev/sdb1 isize=512 agcount=4, agsize=134217600 blks
= sectsz=512 attr=2, projid32bit=1
= crc=1 finobt=0 spinodes=0
data = bsize=4096 blocks=536870400, imaxpct=5
= sunit=0 swidth=0 blks
naming =version 2 bsize=4096 ascii-ci=0 ftype=1
log =internal bsize=4096 blocks=262143, version=2
= sectsz=512 sunit=0 blks, lazy-count=1
realtime =none extsz=4096 blocks=0, rtextents=0
[root@longwave db]# du -h -s .
1.3M .
[root@longwave db]# du -h -s --apparent-size .
81G .
[root@longwave db]# ls
data.mdb lock.mdb
[root@longwave db]#uname - a
Linux longwave 3.10.0-1127.8.2.el7.x86_64 #1 SMP Tue May 12 16:57:42 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
[root@longwave db]# cat /etc/redhat-release
CentOS Linux release 7.8.2003 (Core)
[root@longwave db]#
Client server:
[root@mx01 ~]# urbackupclientctl --version
UrBackup Client Controller v2.4.10.0
[root@mx01 ~]# xfs_info /
meta-data=/dev/sda3 isize=512 agcount=4, agsize=6390464 blks
data = bsize=4096 blocks=25561856, imaxpct=25
log =internal bsize=4096 blocks=12481, version=2
[root@mx01 ~]# du -h -s .
1.3M .
[root@mx01 db]# du -h -s . --apparent-size
81G .
[root@mx01 db]# ls
data.mdb lock.mdb
[root@mx01 db]# uname -a
Linux mx01 3.10.0-1062.18.1.el7.x86_64 #1 SMP Tue Mar 17 23:49:17 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
[root@mx01 db]# cat /etc/redhat-release
CentOS Linux release 7.7.1908 (Core)
[root@mx01 db]#
Any assistance greatly appreciated.
