New settings handling
The major change with server 2.5.x and client 2.5.x is a complete redesign how settings are handled. The goal is to make it more explicit and consistent.
- Each setting has a button next to it which switches between inheriting the setting from the group, using the configuration value on the configuration page and using the value from the client, and for some setting merging client and server settings together
- File backup paths are now a normal setting just like any other. No more separation between paths to backup configured on the client and default directories to backup
This is a critical area of UrBackup and as such needs a lot of testing. Focus should be on if the 2.4.x client still more or less works with the 2.5.x server (and especially doesn’t loose its connection settings for Internet servers).
Linux image backups
2.5.x can backup Linux clients (via dattobd only). The use case is e.g. backing up a DigitalOcean instance. It is explicitly not to create image backups of all possible configurations e.g. LVM, mdraid, btrfs, …
It can “live restore” a root volume, i.e., overwrite the root volume of a currently running machine. So one can image backup e.g. a DigitalOcean droplet. To restore create a new instance (tested with Debian 10/buster) then run the restore script which overwrites the current instance with the backed up instance using a trick to put the currently running system files into (compressed) memory.
Dattobd supports Changed Block Tracking (CBT), so image (and file) backups are done with CBT.
Linux image backup howto
Backup:
- Install dattobd https://github.com/datto/dattobd/blob/master/INSTALL.md
- To only backup used space install partclone (e.g.
apt install partclone). This is currently supported for ext* and xfs. If partclone is not present it’ll backup unused space. - Install the (binary) client and select dattobd for snapshotting
Restore:
- On the server browse to the image backup to restore
- Click on “Restore Linux image”
- Copy & paste the command into a new instance and follow the instructions (the command has a timeout (token), so after a while it should not work anymore)
Testing (image backup + file backup with CBT)
To test if CBT works correctly with file backups please enable Debugging: Verify file backups using client side hashes (for Internet clients with client-side hashing) or Debugging: End-to-end verification of all file backups in the advanced settings.
To test image backups enable md5sums creation on the client via touch /usr/local/var/create_md5sums_imagebackup. The client will then create a file (with date+time in the name) at /usr/local/var/md5sums-* for each image backup listing all files in the image plus their md5sum. Copy that file to server, mount the image backup then verify the md5sums with cd /backup/client/image_mnt; md5sums --quiet -c /path/to/md5sums-file.txt. The only files with checksum errors should be the .datto-*/.overlay-* files in the root directory and swap files (those get automatically excluded from backup).
Thanks for any help with testing and feedback!
As always: Replace the executables (via the installers) and the database of the server/client will be updated on first running it.
Place the files from the update directory into C:\Program Files\UrBackupServer\urbackup or /var/urbackup to auto-update clients. Disable Download client from update server in the server settings to prevent the server from downloading the current version.
On Linux e.g. with this update script: https://github.com/ptempier/get_urbackupclient/blob/master/updateclient.sh
Downgrade process (server)
Stop the UrBackup server, restore C:\Program Files\UrBackupServer\urbackup or /var/urbackup from a backup before upgrade and then install the previous version over the beta release.
On testing beta/WIP versions
Please see Having problems with UrBackup? Please read before posting for what kind of information to add when reporting issues with the beta/WIP version. Reports such as “X does not work” are useless. In general, at the very least, think about what kind of information one would need to reproduce the problem in a different environment. Also a reminder that this is a community project which depends on your contribution and help. Testing is a way to contribute, but without detailed reports on the issues you are finding, you might as well wait for the final release. Best case you debug the problem yourself and then post the fix.
I’ll ignore any issue reports that don’t follow minimum reporting standards.
Changes with server 2.5.5 beta
- Fix blockalign reading/writing to stdin/stdout
- Make last modification time configurable from script list
- Fix backup of symlinks to directories with special characters
Changes with server 2.5.4 beta
- Update SQLite
- Fix JavaScript issue with settings
- Fix db recovery (db repair script)
Changes with server 2.5.3 beta
- Fix db upgrade issue
Changes with server 2.5.2 beta
- Increase timeouts during backup starts from 10s to 60s
- Multi-threaded image compression + compress image with ZSTD now
- Forward image capa to alert script and use it to switch instead of os info
- Backup and restore grub stage 1.5
- Make cleanup log message less ambiguous
- Check if client name is correct before starting backup and offline client if not
- Upgrade LMDB to version 0.9.24
- Use MDB_WRITEMAP and disable MDB_NOMETASYNC
- Don’t encrypt server restore identity when starting restore from web interface
- Fix some issues with the web interface for the new settings handling
- Reset r_online when exiting reconnect loop in image backup
Changes with server 2.5.1 beta
- Changes to support (limited) Linux image backups
- Fixes to new settings handling
- Upgrade to Visual Studio 2019
- Use getrandom instead of reading from /dev/urandom if possible
- Return error message if authentication key is empty
- Fix check if image backup is already queued
- Handle “all_nonusb” setting in image snapshot group
- Fix storing alert state when serialization has null bytes
- Fix backup_dirs_optional display + saving
- Substract sparse extents before checking if file fits on storage
- Upgrade miniz
- Fix polish language name
- Setting to only allow access to settings after the user enters a text
- Add option to send mail SSL encrypted (without STARTTLS)
Changes with client 2.5.3 beta
- Enable script backup for sub-clients
- Fix mariadb backup by using mbstream format
- Ignore backup GPT errors and use primary twice instead on error
- Fix “ALL” file backup dirs handling
Changes with client 2.5.2 beta
- Remove outdated log message for token not found
- Fix problem in fix for piped tar file hash issue after resume
- Improve killing processes with files open for write when restoring to root device on Linux
Changes with client 2.5.1 beta
- Fix rare race condition that makes indexing hange after reconnect
Changes with server 2.5.0 beta
- Rework settings handling
Changes with client 2.5.0 beta
