We are trying out xrtrabackup for our MySQL servers but are getting the following errors in the log:
2017-12-06 23:56:13: Waiting for file hashing and copying threads…
2017-12-06 23:56:14: ERROR: HT: Error getting free space for path “/backup/urBackup/DB20a/171206-2356/urbackup_backup_scripts/mariadbxtrabackup/brp_366/postalmap.ibd”
2017-12-06 23:56:14: Saving file metadata…
2017-12-06 23:56:15: ERROR: Error writing file metadata to file “/backup/urBackup/DB20a/171206-2356/.hashes/urbackup_backup_scripts/mariadbxtrabackup/brp_365/mailrecipient.ibd”
2017-12-06 23:56:15: ERROR: Error writing file metadata -1
2017-12-06 23:56:15: ERROR: Error saving metadata. Could not open output file at “/backup/urBackup/DB20a/171206-2356/.hashes/urbackup_backup_scripts/mariadbxtrabackup/brp_365/mailrecipient.ibd”
2017-12-06 23:56:15: ERROR: Wrong number of embedded meta-data files. Expected 2319 but got 35
2017-12-06 23:56:15: WARNING: Error removing temporary directory “/backup/urBackup/DB20a/171206-2356/.b68xO+K9SCOF35cLk4Bf9Q”. Directory not empty (code: 39)
2017-12-06 23:56:15: Writing new file list…
2017-12-06 23:56:15: ERROR: Fatal error during backup. Backup not completed
2017-12-06 23:56:15: Transferred 130.014 MB - Average speed: 112.506 MBit/s
2017-12-06 23:56:24: ERROR: FATAL: Backup failed because of disk problems (see previous messages)
The test /usr/local/share/urbackup/scripts/mariadbxtrabackup > /dev/null runs fine but we can’t find any information regarding the errors in the log. Does anyone have any idea?
The backup worked fine with just one small database, then we imported 6 more, also small but contains a lot more tables.
We then got an error of to many open files during backup and had to set up open-files-limit and after that we got the error above. Could this be related?
Sorry, attached are the full structure tmp.tar and all files seems to be there. The open-files error is solved as it by standard was 1024 so that should not be an issue anymore.
"ERROR: HT: Error getting free space for path “/backup/urBackup/DB20a/171206-2356/urbackup_backup_scripts/mariadbxtrabackup/brp_366/postalmap.ibd”
postalmap.ibd is the “largest” table right now (just 20000 rows but all the others have below 1000) it that is any hint
“ERROR: Wrong number of embedded meta-data files. Expected 2319 but got 35”
Is this urbackups internal files or is it an error from xtrabackup
12/11/17 19:31 INFO Transferred 130.014 MB - Average speed: 100.92 MBit/s
12/11/17 19:31 DEBUG Script does not exist urbackup/post_incr_filebackup
12/11/17 19:31 INFO Time taken for backing up client DB20a: 30s
12/11/17 19:31 INFO Backup succeeded
Hi
We are having some trouble with xtrabackup again. /usr/local/share/urbackup/scripts/mariadbxtrabackup > /dev/null manually is running fine without errors.
But the log from urbackup is filled with errors, log is attached
We got this problem after upgrading urBackup server to 2.2.11 on ubuntu 16.04. Client is 2.2.5, Mysql server is 5.7 and xtrabackup is upgraded to 2.4.11.
Had another go at xtrabackup but still problems. The backup job runs for a while then the client crashes with the following in the kernel log: PipeFile: stdou[12957]: segfault at 7f14e805d000 ip 0000557b7662b1c5 sp 00007f14d3ffeac8 error 6 in urbackupclientbackend[557b7646d000+2f4000]
Attached are the debug log from the client and the serverlog.
Server is Ubuntu 18.04 with UrBackup Server 2.3.8
Client is Ubuntu 16.04 with UrBackup Client 2.3.4
MySQL 5.7.23 and xtrabackup 2.4.15-1
