Hi @kot1grun
could you start packaging UrBackup Server/Client 2.0.30/2.0.29?
Packaging should be significantly easier:
- I removed all the shared libraries. It’s just executables now
- The wrapper scripts are gone and the executables can be used directly
- It has an optional embedded cryptopp now (enable with
--enable-embedded-cryptoppat configure), so you don’t need the separate cryptopp package anymore
