Downgrade to 2.3.8
Is there a way to downgrade from 2.4.9 to 2.3.8.?
rkshack
From the Testing forum:
Downgrade process (server)
Stop the UrBackup server, restore C:\Program Files\UrBackupServer\urbackup or /var/urbackup from a backup before upgrade and then install the previous version over the beta release.
Be sure the database backup you restore is from before you upgraded to the 2.4.x version. If you’re not keeping separate copies of the “urbackup” folder/directory from your Backup storage path (Settings: Server) then you get to reinstall with default settings and start over with the experience you gained the first time.
Anyone know where to find a copy of URBackup server 2.3.8 RPM for CentOS 7? The openSUSE repository only has the latest version (2.4.9).
