Does Image backup backup mount points?
I am running cmd-line client on the urBackup Server. Currently have image backups disabled.
I have 3 physical disks on the Server.
They are:
/ (Root filesystem and applications)
/Shares ( mount point - for all my docs, music, photos, etc.)
/PC_Backups ( mount point - repository for all urBackup PC backups )
rsync replicates all the files in the two mount points to a backup server with same configuration so I only want to backup /
I see no file/folder exclusion for Client Image Backup
Will urBackup skip the mount points or is there a way to configure it to do so on image backups?
Image backups are only supported for Windows clients.
Good to know, thanks
