Had a few backup jobs running over the weekend from the same Server 2016 machine. All of them incremental file backups. The first six jobs/retries ended early with this or similar:
Info
2024-03-15 00:10
Starting scheduled incremental file backup...
Info
2024-03-15 00:30
Scanning for changed hard links on volume of "D:\"...
Fel
2024-03-15 00:30
Error while getting files in folder "\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy5\Profiler\PeterG.V6\AppData\Roaming\Mozilla\Firefox\Profiles\rsftfmm7.default\storage\default\https+++www.youtube.com\idb\1131144353LCo7g%sCD7a%tda2bdads.files". Windows errorcode: 87. Access to root directory is gone too. Shadow copy was probably deleted while indexing.
Fel
2024-03-15 00:30
Indexing files failed, because of error
Fel
2024-03-15 00:30
Constructing of filelist of "Radio1" failed: error - index error
Fel
2024-03-15 00:30
The last job managed to end but with issues, the log gave 25 of these errors for different files in the same firefox profile directory of a single user:
Fel
2024-03-17 19:53
Error getting complete file "1BwqRFofRk1lurv1eXp4|D/Profiler/PeterG.V6/AppData/Roaming/Mozilla/Firefox/Profiles/rsftfmm7.default/storage/default/https+++www.youtube.com^partitionKey=%28https%2Cgoogle.com%29/idb/2805597024LCo7g%sCD7a%tfadbca1s.files" from Radio1. Errorcode: CANNOT_OPEN_FILE (3)
Looking at the parent folder, in this case D:\Profiler\PeterG.V6\AppData\Roaming\Mozilla\Firefox\Profiles\rsftfmm7.default\storage\default\https+++www.youtube.com^partitionKey=%28https%2Cgoogle.com%29\idb, it is indeed missing the mentioned file and the last modified date is 08-03-2024. This seems to be the case for all of the parent directories referenced.
vssadmin list shadows shows no stray copies left behind, vssadmin list shadowstorage shows 0 bytes is used for the volume in question.
Tried restarting the urbackup services on the client and server, then running a new incremental file backup, again it failed referencing a folder that does not exist, with a parent folder that was last modified three days ago.
Any ideas why this might be, and how to solve?
Best regards
Alexander
