Hello , i have a problem with the connection between server and client , i use the versiune 2.0.36 both client and server .The main problem is with the connection , first when i installed the client and server everything is working properly , the backup is doing , but after 2-3 days the connection it was lost and the server it was inaccessible to connect to client.
The single solution it was to remove the client and reinstall it and after that everything it was working, but can you help me with some other solution other than remove and reinstall the client?Thank you in advice.
Sorry you are having issues. To solve the problem the client (debug) log would be useful.
If possible, could you post it or send it?
This post describes how to change the client to debug logging, where it is stored and where to send it to if posting is not possible: Having problems with UrBackup? Please read before posting
Hello again , thank you for the answer the log is below
2016-10-21 10:27:24: WARNING: Upgrading…
2016-10-21 10:27:24: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=‘db_version’]: no such table: misc
2016-10-21 10:27:25: ERROR: Error preparing Query [DROP INDEX filehashes_idx]: no such index: filehashes_idx
2016-10-21 10:34:40: ERROR: Recvfrom error in CUDPThread::UdpStep
2016-10-21 10:34:40: ERROR: Last error: 10038
2016-10-21 10:35:05: WARNING: Info not found at ‘c:’ - reindexing
2016-10-21 10:35:21: WARNING: Info not found at ‘d:’ - reindexing
2016-10-21 10:36:39: WARNING: Writer MSDEWriter has failure state VSS_WS_STABLE with error VSS_E_WRITERERROR_NONRETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2016-10-21 10:58:00: WARNING: Writer MSDEWriter has failure state VSS_WS_STABLE with error VSS_E_WRITERERROR_NONRETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
Thank you for answer.
Can you put it into debug log mode and post/attach a debug log file?
debug.log (935 Bytes)
Yes , sure i already uploaded the debug. Thank you.
Hello uroni, do you have a solution for this problem :)?
