i managed to capture the logs off of the client PC.
2016-11-04 08:13:08: WARNING: Upgrading…
2016-11-04 08:13:08: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=‘db_version’]: no such table: misc
2016-11-04 08:13:09: ERROR: Error preparing Query [DROP INDEX filehashes_idx]: no such index: filehashes_idx
2016-11-04 08:14:11: WARNING: Info not found at ‘c:’ - reindexing
2016-11-04 08:16:53: WARNING: Info not found at ‘C:’ - reindexing
2016-11-05 10:54:12: WARNING: There are 1837912 new USN entries at ‘C:’ - reindexing
2016-11-07 11:48:05: Loaded -fileserv- plugin
2016-11-07 11:48:05: Loaded -fsimageplugin- plugin
2016-11-07 11:48:05: Loaded -cryptoplugin- plugin
2016-11-07 11:48:05: Created new database connection for urbackup/backup_client.db
2016-11-07 11:48:05: urbackupserver: Server started up sucessfully!
2016-11-07 11:48:05: FileSrv: Backup privileges set successfully
2016-11-07 11:48:05: FileSrv: Info: retval 0
2016-11-07 11:48:05: FileSrv: Info: Window size=524288
2016-11-07 11:48:05: FileSrv: Binding udp socket at port 35622…
2016-11-07 11:48:05: FileSrv: done.
2016-11-07 11:48:05: FileSrv: Disabling new behavior…
2016-11-07 11:48:05: FileSrv: Servername: -SUZANNE3-
2016-11-07 11:48:05: FileSrv: Server started up sucessfully
2016-11-07 11:48:05: FileSrv: UDP Thread startet
2016-11-07 11:48:05: Started UrBackupClient Backend…
2016-11-07 11:48:05: urbackupserver: No available slots… starting new Worker
2016-11-07 11:48:05: ClientService cmd: #Iyt1ZZbH3mJx5BvTCSMtd#1CHANNEL capa=2112
2016-11-07 11:48:05: New channel: Number of Channels: 1
2016-11-07 11:48:05: Filesystem. Vol="\?\Volume{f83247d5-cf6b-11e2-bf2f-806d6172696f}" Name="" Type=“ntfs” VPaths=1 Size=80023715840
2016-11-07 11:48:05: Filesystem is System partition. Skipping…
2016-11-07 11:48:05: Filesystem. Vol="\?\Volume{9ab98658-1bcc-11e3-90ae-806d6172696f}" Name="" Type="" VPaths=1 Size=-1
2016-11-07 11:48:05: Bootable flag not set for volume
2016-11-07 11:48:05: Found no SYSVOL on the same physical device as ‘C’.
2016-11-07 11:48:06: Internet only mode not enabled. Waiting for local server for 3:00…
2016-11-07 11:48:06: Looking for old Sessions… 0 sessions
2016-11-07 11:48:06: Created new database connection for urbackup/backup_client.db
2016-11-07 11:48:06: Final path: C
2016-11-07 11:48:16: Change: C: [fn=Outbox.dbx,reason=USN_REASON_DATA_OVERWRITE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8896848,FRN=844424930162614,Parent FRN=1407374883583138,Version=2]
2016-11-07 11:48:16: Change: C: [fn=open_files.dat,reason=USN_REASON_DATA_EXTEND|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8896928,FRN=16325548649293498,Parent FRN=2533274790476018,Version=2]
2016-11-07 11:48:16: Change: C: [fn=etilqs_JOOJMj5w1jnD1Pj,reason=USN_REASON_FILE_DELETE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_HIDDEN|FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_TEMPORARY,USN=8897016,FRN=5910974510999766,Parent FRN=281474976710728,Version=2]
2016-11-07 11:48:16: Change: C: [fn=etilqs_I0XjRFaDPzt73g0,reason=USN_REASON_FILE_DELETE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_HIDDEN|FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_TEMPORARY,USN=8897216,FRN=3940649674025252,Parent FRN=281474976710728,Version=2]
2016-11-07 11:48:16: Change: C: [fn=wbemess.log,reason=USN_REASON_DATA_EXTEND,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8897320,FRN=36028797018966676,Parent FRN=281474976710800,Version=2]
2016-11-07 11:48:16: Change: C: [fn=wbemess.log,reason=USN_REASON_DATA_EXTEND|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8897408,FRN=36028797018966676,Parent FRN=281474976710800,Version=2]
2016-11-07 11:48:16: Change: C: [fn=debug.log,reason=USN_REASON_DATA_EXTEND,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8897496,FRN=13510798882183728,Parent FRN=32088147345082432,Version=2]
2016-11-07 11:48:16: Change: C: [fn=urbackup_client_tmp,reason=USN_REASON_FILE_DELETE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_DIRECTORY,USN=8897576,FRN=2251799813765371,Parent FRN=281474976710728,Version=2]
2016-11-07 11:48:16: Change: C: [fn=urbackup_client_tmp,reason=USN_REASON_FILE_CREATE,attributes=FILE_ATTRIBUTE_DIRECTORY,USN=8897680,FRN=6192449487710422,Parent FRN=281474976710728,Version=2]
2016-11-07 11:48:16: Change: C: [fn=urbackup_client_tmp,reason=USN_REASON_FILE_CREATE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_DIRECTORY,USN=8897784,FRN=6192449487710422,Parent FRN=281474976710728,Version=2]
2016-11-07 11:48:16: Change: C: [fn=settings.cfg,reason=USN_REASON_SECURITY_CHANGE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8898080,FRN=34902897112151331,Parent FRN=4222124650739958,Version=2]
2016-11-07 11:48:16: Change: C: [fn=settings.cfg,reason=USN_REASON_SECURITY_CHANGE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8898168,FRN=34902897112151331,Parent FRN=4222124650739958,Version=2]
2016-11-07 11:48:16: Change: C: [fn=urbackup,reason=USN_REASON_SECURITY_CHANGE,attributes=FILE_ATTRIBUTE_DIRECTORY,USN=8898256,FRN=2533274790476018,Parent FRN=32088147345082432,Version=2]
2016-11-07 11:48:16: Change: C: [fn=urbackup,reason=USN_REASON_SECURITY_CHANGE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_DIRECTORY,USN=8898336,FRN=2533274790476018,Parent FRN=32088147345082432,Version=2]
2016-11-07 11:48:16: Change: C: [fn=data,reason=USN_REASON_SECURITY_CHANGE,attributes=FILE_ATTRIBUTE_DIRECTORY,USN=8898416,FRN=4222124650739958,Parent FRN=2533274790476018,Version=2]
2016-11-07 11:48:16: Change: C: [fn=data,reason=USN_REASON_SECURITY_CHANGE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_DIRECTORY,USN=8898488,FRN=4222124650739958,Parent FRN=2533274790476018,Version=2]
2016-11-07 11:48:16: Change: C: [fn=debug.log,reason=USN_REASON_DATA_EXTEND|USN_REASON_SECURITY_CHANGE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8898560,FRN=13510798882183728,Parent FRN=32088147345082432,Version=2]
2016-11-07 11:48:16: Change: C: [fn=Outbox.dbx,reason=USN_REASON_DATA_OVERWRITE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8898640,FRN=844424930162614,Parent FRN=1407374883583138,Version=2]
2016-11-07 11:48:16: Change: C: [fn=MSIMGSIZ.DAT,reason=USN_REASON_DATA_OVERWRITE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8898720,FRN=281474976742894,Parent FRN=844424930153589,Version=2]
2016-11-07 11:48:16: Change: C: [fn=index,reason=USN_REASON_DATA_OVERWRITE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8898808,FRN=4785074604132355,Parent FRN=10414574138340234,Version=2]
2016-11-07 11:48:16: Change: C: [fn=debug.log,reason=USN_REASON_DATA_OVERWRITE|USN_REASON_DATA_EXTEND|USN_REASON_SECURITY_CHANGE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8898880,FRN=13510798882183728,Parent FRN=32088147345082432,Version=2]
2016-11-07 11:48:16: Change: C: [fn=index,reason=USN_REASON_DATA_OVERWRITE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8898960,FRN=3377699720600967,Parent FRN=3659174697308508,Version=2]
2016-11-07 11:48:16: Change: C: [fn=open_files.dat,reason=USN_REASON_SECURITY_CHANGE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8899032,FRN=16325548649293498,Parent FRN=2533274790476018,Version=2]
2016-11-07 11:48:16: Change: C: [fn=wbemess.log,reason=USN_REASON_DATA_EXTEND,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8899120,FRN=36028797018966676,Parent FRN=281474976710800,Version=2]
2016-11-07 11:48:16: Change: C: [fn=wbemess.log,reason=USN_REASON_DATA_EXTEND|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8899208,FRN=36028797018966676,Parent FRN=281474976710800,Version=2]
2016-11-07 11:48:16: Change: C: [fn=URBACKUPCLIENTBACKEND.EXE-05ABFB27.pf,reason=USN_REASON_DATA_TRUNCATION,attributes=FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_NOT_CONTENT_INDEXED,USN=8899296,FRN=38280596832682971,Parent FRN=281474976721052,Version=2]
2016-11-07 11:48:16: Change: C: [fn=URBACKUPCLIENTBACKEND.EXE-05ABFB27.pf,reason=USN_REASON_DATA_EXTEND|USN_REASON_DATA_TRUNCATION,attributes=FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_NOT_CONTENT_INDEXED,USN=8899432,FRN=38280596832682971,Parent FRN=281474976721052,Version=2]
2016-11-07 11:48:16: Change: C: [fn=URBACKUPCLIENTBACKEND.EXE-05ABFB27.pf,reason=USN_REASON_DATA_EXTEND|USN_REASON_DATA_TRUNCATION|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_NOT_CONTENT_INDEXED,USN=8899568,FRN=38280596832682971,Parent FRN=281474976721052,Version=2]
2016-11-07 11:48:16: Change: C: [fn=URBACKUPCLIENTBACKEND.EXE-05ABFB27.pf,reason=USN_REASON_DATA_OVERWRITE,attributes=FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_NOT_CONTENT_INDEXED,USN=8899704,FRN=38280596832682971,Parent FRN=281474976721052,Version=2]
2016-11-07 11:48:26: Change: C: [fn=open_files.dat,reason=USN_REASON_DATA_EXTEND|USN_REASON_SECURITY_CHANGE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8900064,FRN=16325548649293498,Parent FRN=2533274790476018,Version=2]
2016-11-07 11:48:26: Change: C: [fn=open_files.dat,reason=USN_REASON_DATA_OVERWRITE|USN_REASON_DATA_EXTEND|USN_REASON_SECURITY_CHANGE,attributes=FILE_ATTRIBUTE_ARCHIVE,USN=8900608,FRN=16325548649293498,Parent FRN=2533274790476018,Version=2]
2016-11-07 11:48:26: Change: C: [fn=etilqs_I0OfMvOcVzRhCOh,reason=USN_REASON_FILE_CREATE,attributes=FILE_ATTRIBUTE_HIDDEN|FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_TEMPORARY,USN=8900696,FRN=4503599627446564,Parent FRN=844424930152471,Version=2]
2016-11-07 11:48:26: Change: C: [fn=etilqs_I0OfMvOcVzRhCOh,reason=USN_REASON_DATA_EXTEND|USN_REASON_FILE_CREATE,attributes=FILE_ATTRIBUTE_HIDDEN|FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_TEMPORARY,USN=8900800,FRN=4503599627446564,Parent FRN=844424930152471,Version=2]
2016-11-07 11:48:26: Change: C: [fn=etilqs_I0OfMvOcVzRhCOh,reason=USN_REASON_DATA_OVERWRITE|USN_REASON_DATA_EXTEND|USN_REASON_FILE_CREATE,attributes=FILE_ATTRIBUTE_HIDDEN|FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_TEMPORARY,USN=8900904,FRN=4503599627446564,Parent FRN=844424930152471,Version=2]
2016-11-07 11:48:26: Change: C: [fn=etilqs_I0OfMvOcVzRhCOh,reason=USN_REASON_DATA_OVERWRITE|USN_REASON_DATA_EXTEND|USN_REASON_FILE_CREATE|USN_REASON_FILE_DELETE|USN_REASON_CLOSE,attributes=FILE_ATTRIBUTE_HIDDEN|FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_TEMPORARY,USN=8901008,FRN=4503599627446564,Parent FRN=844424930152471,Version=2]
2016-11-07 11:48:41: FileSrv: UDP: PING received… sending PONG. Delay=70ms
2016-11-07 11:49:05: ClientService cmd: PONG
2016-11-07 11:49:06: Change: C: [fn=etilqs_AXRumL7N8Bz0DAf,reason=USN_REASON_FILE_CREATE,attributes=FILE_ATTRIBUTE_HIDDEN|FILE_ATTRIBUTE_ARCHIVE|FILE_ATTRIBUTE_TEMPORARY,USN=8901672,FRN=5066549580867876,Parent FRN=844424930152471,Version=2]
