In addition, it ALSO shows CBT active for the ONE volume it’s NOT set to be active, and the ones set to use it are shown as “Without CBT”, and yes I’ve run an image over those (and not the one showing active) and rebooted multiple times!
Windows 10 Pro x64 all updates current.
I have:
Run the windows troubleshooter rebooted as it said - no change
Uninstalled the client - rebooted - blessed silence from the notification bar
reinstalled the client - issue back
rebooted 3 times - notice that I need to reboot at EVERY BOOT including the third one
set it to not use CBT - issue STILL there
this is the one client where I actually need CBT but it WILL NOT WORK without extremely annoying popups - and then it’s random about if it shows active or not.
How do I either:
get it effing working
or
Cause UrRbackup to serve the NON-CBT client to that specific machine
Note that that’s the worst case option, I’d actually like CBT working on this box.
I only have the machine on site for a limited time and need to fix this NOW, not the week after next when I can’t access the machine!
@uroni this has been going on for MONTHS ever wonder why I’m not buying more licences for more clients? I would if I could get it to WORK.
I’m also getting warnings in the event log Event 225 src Kernel-PnP urbctctl_lock.exe .. stopped removal or ejection of STORAGE\Volume\{........}#....... lots of them.
Setting CBT to disabled also has no effect.
