How should I proceed to track down the following problem?
My UrBackup Server v2.4.9.0 is on Debian stretch virtual server:
Linux curlew 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u1 (2019-09-20) x86_64 GNU/Linux
The same server is running UrBackup Client Backend v2.3.4.0.
I recently realized I was not backing up an area of the server so I added a job.
I have:
a job that backs up / with an exclusion of /srv
a job that backs up /srv/sync (on /dev/vde)
the new job that backs up /srv/samba (on /dev/vdd)
Prior to adding the new job the /srv/sync job worked but now it backs up the wrong directory, the same directory as the added job.
The snapshot mount log entries from 5 successive job runs are:
12/11/19 09:20 Snapshotting device /dev/vde via dattobd... (existing [sync] job)
12/11/19 12:33 Snapshotting device /dev/vdd via dattobd... (first run of new [samba] job)
13/11/19 01:12 Snapshotting device /dev/vdd via dattobd... (existing [sync] job - wrong device mounted)
13/11/19 15:10 Snapshotting device /dev/vdd via dattobd... (second run of new [samba] job)
13/11/19 15:19 Snapshotting device /dev/vdd via dattobd... (existing [sync] job - wrong device mounted)
It seems that there is some confusion of jobs but I am not sure how to track it down, the settings on the server for each job seem correct in the server web interface.
*** /usr/local/share/urbackup/dattobd_create_filesystem_snapshot.o 2019-08-11 02:04:51.205694174 +1000
--- /usr/local/share/urbackup/dattobd_create_filesystem_snapshot 2019-11-14 01:25:38.182749257 +1100
*************** then
*** 37,43 ****
exit 1
fi
! echo "Snapshotting device $DEVICE via dattobd..."
NUM=0
--- 37,43 ----
exit 1
fi
! echo "Snapshotting device $DEVICE via dattobd for $TYPE mountpoint $SNAP_MOUNTPOINT snap $SNAP_ID ..."
NUM=0
*************** fi
*** 104,107 ****
echo "SNAPSHOT=$SNAP_DEST"
! exit 0
\ No newline at end of file
--- 104,107 ----
! exit 0
I had disabled the /srv/samba and /srv/sync backups so I enabled the /srv/sync job which reported:
14/11/19 01:28 Snapshotting device /dev/vde via dattobd for ext4 mountpoint /srv/sync snap ec4a52693cbc14c56eb7adfad6ba6aa97494b93ab80fc359
Once it completed I enabled the /srv/samba job which reported:
14/11/19 01:33 Snapshotting device /dev/vdd via dattobd for ext4 mountpoint /srv/samba snap 60057770ff9ef9163883efd93b8aed222d973dd88effcce4
So maybe I have a correct backup when I force a strict separation of the jobs. They were running sequentially before but the /srv/sync job was immediately after the /srv/samba job as its start time occurred before the first job finished.
I have “Max simultaneous backups” set to 2 and “Maximum number of simultaneous jobs per client” set to 1.
