first, thank you for this piece of software.
But I’m stuck in setting up ZFS for backing up files and images.
I’ve followed the steps described in 11.7.1 in the manual. Image backups do work, but file backups do not. I’m confused about the settings in /etc/urbackup/backupfolder and the backup storage path set in the gui. I’ve set both values to the same path wich do not work for the file backups but do work for the image backups. I’ve set up the datasets and mountpoints to match my enviroment.
Excerpt from the log:
Errors | 15.10.20 11:01 | Error creating empty file subvolume. "cannot mount ‘/media/BACKUP/hu/windows/S101-APP01’: directory is not empty |
Errors | 15.10.20 11:01 | Cannot create directory /media/BACKUP/hu/windows/S101-APP01/201015-1101 for backup (server error). cannot mount ‘/media/BACKUP/hu/windows/S101-APP01’: directory is not empty |
Errors | 15.10.20 11:01 | Backup failed |
Any hint would be nice. Especially for the settings in /etc/urbackup/backupfolder and the backup path set in the gui.
Cheers
Knuuut
