until I tried Linux clients I was really enthusiastic about Urbackup. Server installation on Ubuntu Server with ZFS was easy, although apparently not everything works with ZFS. I have to manually delete dataset from clients that no longer exist, but otherwise everything is ok.
Now I really struggle to get Linux Clients running, a Manjaro client did not survive the client installation from AUR and with Xubuntu I first tried ZFS, which at least worked so far that the server wanted to make an image backup but aborted with the error message “can not read MBR”. Then I also tested LVM in Bios Mode. The client shows up on the server, but nothing works, it shows Image Backup not supported and no paths configured. What’s wrong I have configured paths on both the client and the server?
urbackupclientctl list-backupdir
PATH NAME FLAGS
/home home follow_symlinks,symlinks_optional,share_hashes
As a last attempt, I installed Xubuntu with BTRFS and UEFI, the same result, no paths for file backup and image backup not supportet. I’ve seen that others here are using Ubuntu 22.04 as a client even though dattobd is not available for this version, what am I doing wrong?
> root@dispo19:~# journalctl | grep -i urbackup
> Okt 03 08:51:39 dispo19 systemd[1]: Configuration file /lib/systemd/system/urbackupclientbackend.service is marked executable. Please remove executable permission bits. Proceeding anyway.
> Okt 03 08:51:39 dispo19 systemd[1]: Started UrBackup Client backend.
> Okt 03 08:52:15 dispo19 urbackupclientbackend[1485]: WARNING: Shutting down (Signal 15)
> Okt 03 08:52:15 dispo19 systemd[1]: Stopping UrBackup Client backend...
> Okt 03 08:52:15 dispo19 systemd[1]: urbackupclientbackend.service: Deactivated successfully.
> Okt 03 08:52:15 dispo19 systemd[1]: Stopped UrBackup Client backend.
> Okt 03 08:52:52 dispo19 systemd[1]: Configuration file /lib/systemd/system/urbackupclientbackend.service is marked executable. Please remove executable permission bits. Proceeding anyway.
> Okt 03 08:52:54 dispo19 systemd[1]: Started UrBackup Client backend.
> Okt 03 08:52:54 dispo19 urbackupclientbackend[766]: ERROR: Error joining ipv6 multicast group ff12::f894:d:dd00:ef91
> Okt 03 08:53:41 dispo19 urbackupclientbackend[1138]: No LSB modules are available.
> Okt 03 09:27:14 dispo19 systemd[1]: Configuration file /lib/systemd/system/urbackupclientbackend.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Best Regards
