See the solution to the problem below in the Edit section :
Hi there,
I’ve been trying out UrBackup with great interest, but I have hit a bit of a wall when it comes to restoring through a XenServer VM (6.5)
I can load the live CD in from ISO just fine, and restore without issues, however, without XenTools installed, the VM uses the Xenserver emulated Realtek 8139 network card (100 mbit), instead of 1 GB Citrix PV Adapter it could be.
Now i’ve tried setting the VM parameters to use eliloader and pygrub, but eliloader doesn’t want to start (problems recognizing the vmlinuz and initrd file, and pygrub does load the VM and start the ISO, but it bypasses the grub menu, starts the vmlinuz and initrd and loads, but dumps me at the debian login prompt, not auto logging in to user urbackup.
The first thing i would like to try is if the network card is actually found and runs at 1 GBps, but for that I need to get in debian, but without the username and password of urbackup/admin or root and starting the recovery client using /root/start.sh, that’s not going to work. Or i’ll need to create a debian live CD that includes the Xenserver Tools, but doing that in debian and creating a live CD from it is a fair bit out of my comfort zone. I’m fairly knowledgeable in CentOS, but Debian is a whole new ballgame.
I’m almost afraid to ask, but would anyone mind sharing the login credentials for the live ISO? Or perhaps someone else who has experience with UrBackup bare metal restore in XenServer?
[EDIT]:
For those interested, to get a XenServer VM to work with a Xen Net pv adapter, just create a new VM based on the Debian 7.0 (32-bit) Wheezy template and put the UrBackup restore ISO in the virtual machine’s DVD drive. Now open up a SSH console to your Xenserver, and adjust the bootloader to pygrub and erase other bootloader options with this command:
xe vm-param-set uuid= PV-bootloader=pygrub
xe vm-param-set uuid= PV-bootloader-args=""
The vm-uuid is found in Xencenter, on the general tab of the virtual machine, or from SSH console using: xe vm-list
Now there’s a bit of a downside, that is that UrBackups live CD auto starts and auto logs in from a tty console. When you make this adjustment, the pygrub bootloader will use another console, namely hvc0. Instead of auto logging in, it will present you with a debian login prompt ones the restore CD is done booting.
Just login to the CD with:
Username: urbackup
Password: live
then run the command: sudo /root/start.sh
Now you can run the restore as normal, but with a Xen PV Network adapter that should run at 1 or 2 Gbps instead of the default HVM emulated Realtek 8139 network card (100 mbps).
Another small point to keep in mind, the vm template you used, adds a small 8 GB hard disk to the VM. Dont remove that one, you can edit it to make it bigger for the size of the restore you want to do, or add additional disks. If you remove the drive, the VM will not boot anymore. This must be a parameter in the VM somewhere that i havent found yet.
Another thing to consider, after the restore of a Windows image, you can’t just reboot and start Windows, pygrub doesn’t seem to want to start a windows restore and gives the error: Internal Error, there is no bootable device. To solve this, just create a new VM with the right template (windows 2012 R2 template for example), after creation, delete the new disk drive that you don’t need. Detach the disk(s) from the restore VM and attach them again in the new Windows template you just created, and voila, it boots normally. You should be able to convert the VM metadata from Paravirtualized (PV) back to Hardware-assisted Virtualization (HVM), but i haven’t found the correct commands to do so, i keep getting inaccessible boot device BSOD’s when I try. The attaching of the disk in a new VM works fine though.
Very long winded explanation, but this is the way I found out to use a GB adapter for restores in XenServer, instead of restoring at 100 mbit. Waiting for 43 minutes for a 30 GB machine to be restored using a 100 mbit network card might be ok for a private pc, but I can imagine not so much in a commercial setting…
