Wrong client update info at update2.urbackup.org for V1.4.9
Hello @all,
i updatet to Urbackup 1.4.9 and the server won´t update the clients to 1.4.9. So i looked at our firewall: The urbackup Server is looking at update2.urbackup.org for the client version. The files at update2.urbackup.org are pointing to the client version V1.4.8.
Can anyone change the files at update2.urbackup.org to V1.4.9? Thanx.
Greets
Marco
Has no one else these problem?
Greets
Marco
I have the same issue. Was thinking maybe there is a grace period before the links are updated, or maybe odd releases are for testing. I was waiting to see if your post had a reply but you are not the only one.
Sorry. I try to delay the auto-update a little bit. Especially in this case, as there were no bug fixes – only changes that can potentially break stuff. Will update it tomorrow.
OK, thanks for the hint.
Greets
Marco
still need to change the server_version_info.properties ?
That was fast!
I messed up and did not adjust the version in the actual release, so the message on the server interface would not go away. In this case it does not matter as this release is not important for most people.
thanks for the quick replies. Great software.
