Win7х64 clients goes to offline over time
Hi!
First of all I want to thank developers of UrBackup. This is the best soft of backup!
I have some problem with last versions. UrBackup clients (Win7х64) goes to offline over time on some computers.
I turned on debug and got log (part of log):
[skip]
0-1418739122-Waiting for file transfers…
0-1418739126-Writing new file list…
0-1418739126-Waiting for file hashing and copying threads…
0-1418739127-Transferred 6.00977 KB - Average speed: 9.888 KBit/s
0-1418739127-Time taken for backing up client S_ANOHIN: 39s
0-1418739127-Backup succeeded
2014-12-16 17:12:07: rc=0 hasError=true state=0
2014-12-16 17:12:12: FileSrv: ClientThread deleted. 1024 KB Memory freed.
2014-12-16 17:12:12: ClientService cmd: PONG
2014-12-16 17:12:13: FileSrv: UDP: PING received… sending PONG. Delay=61ms
2014-12-16 17:12:13: FileSrv: UDP: PING received… sending PONG. Delay=213ms
2014-12-16 17:12:13: ERROR: Recvfrom error in CUDPThread::UdpStep
2014-12-16 17:12:13: CUDPThread exited.
2014-12-16 17:12:28: ClientService cmd: STATUS#pw=GMqVRIhsQwK3Ee0ArdgrKoNvv6ysyo
2014-12-16 17:12:28: rc=0 hasError=true state=0
2014-12-16 17:12:28: ClientService cmd: GET INCRINTERVALL#pw=GMqVRIhsQwK3Ee0ArdgrKoNvv6ysyo
2014-12-16 17:13:12: ClientService cmd: PONG
2014-12-16 17:13:28: ClientService cmd: STATUS#pw=GMqVRIhsQwK3Ee0ArdgrKoNvv6ysyo
2014-12-16 17:13:28: rc=0 hasError=true state=0
2014-12-16 17:13:28: ClientService cmd: GET INCRINTERVALL#pw=GMqVRIhsQwK3Ee0ArdgrKoNvv6ysyo
[skip]
On UrBackup server client state is offline, but if I restart “Urbackup client service” on client computer, state will be online, but then goes to offline over time. This situation is repeated on some computers and I do not see any pattern.
Please tell me a possible solution?
Thanks for the report!
That seems to be the problem. Can you try this one http://raspberrybuild.urbackup.org/misc/UrBackup%20Client%201.4.7.exe and tell us the results?
Thank you for quick answer! I installed version 1.4.7, check how it works.
Working so good for few hours!
Thank you very much! When you publish official update?
