On the client machine (Win10pro) an urbackup agent and vipnet client is installed. Vipnet blocks any connection to the computer (in technical support of vipnet said that this should work). However, if you run a backup of the system on the computer itself, then the backup starts.
Can anyone have a script to launch the agent from the client side, which can be thrust into the sheduler?
