Hello
I am trying to backup a Proxmox main server root directory
Server settings for this specific client:
Excluded files (with wildcards): /rpool/*;/mnt/proxmox-hostname/*;/tmp/*;/var/lib/lxcfs/*;/mnt/data/*
Default directories to backup: / (root directory)
I get a log error: “Error while listing files in folder “/var/lib/lxcfs”. User may not have permissions to access this folder. Errno is 0” and “Indexing files failed, because of error” the backup fails completely.
I have tested : /var/lib/lxcfs/*; */lxcfs/*;
I can not make it work. It seems always failing during file indexing (~1 to 3 seconds from start) no matter what i wild cards combo i have used
Any suggestions??
If i select single directory, (i.e. /etc) i can backup. The issues is with indexing the files in the lxc container. It will be great to “Exclude directory” , rather than files
Thank you
