When add new client, which is Internet client/client behind NAT or client via IP/hostname hint ?
Hi jay, i’m not sure exactly what you mean. Did you check the server logs if there any connection issues? did you check if the server port is reachable from the client using a tool like telnet to test if the port is open?
