i am using urbackup also on a remote location (over the internet)
when i instaiing the client it automaticly opens the firewall on my remote windows server.
BUT!
which port is that
i want to remove the auto created firewallrule and replace it for my own rule
which port has to be opened on CLIENT side ???
on the server side its 55415 …but the client ???
i tried also TCP 55415
but then i get : Connecting Channel to ClientService failed - CONNECT error -55
and
Connecting to ClientService of “SERVER1” failed: Error sending ‘running’ ping to client
can you please HELP me ??
many thanks in advance
micheal
I am using Windows Front end, what port I need to use?
In back end I I am using port number 55413. If I use this port number in front end, it connects to back end but when front end sends “STATUS” cmd, back end is not responding and front end shows socket IO error.
I am using back end(server) as client.
Please help.
