Hi
We have configurated two file backups for each client. In some of them there are two folders as expected but the current symlink is pointing to another folder which don’t exists. With the manual cleaning it says that couldn’t make stat over that folder because it does not exists. So, how can I correct it in a clean way? just creating by hand a symlink pointing to an existing folder is enough?
thanks in advance
