Hi everyone,
thank you for creating UrBackup, very useful. I use it on local network on http, and it works nicely. Now i would like to switch to SSL, but can’t make it work. I followed the official instructions, then other different guides and forums on the net, including all tickets in this forum regarding webinterface, but still can’t make webinterface appear on screen through ssl. Can you please help? I am running Ubuntu 18.04, i did compile UrBackup from sources. What other information would you need? Please see picture on what is happening. Thank you very much for hints and help.
I am getting this error: [Sun Oct 14 22:58:38.017294 2018] [fastcgi:error] [pid 14140] [client 192.168.1.2:56570] FastCGI: incomplete headers (0 bytes) received from server “/var/www/urbackup/x”, referer: https://192.168.1.3:55413/
lsb_release -a
Distributor ID: | Ubuntu |
Description: | Ubuntu 18.04.1 LTS |
Release: | 18.04 |
Codename: | bionic |
dpkg -l urbackup-server
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
rc urbackup-server 2.2.11.2193-1 amd64 Server for backing up clients
