The urbackp server needs to be reverse proxied from apache as it is listening to port 55413
I access urbackup as https://server.name.local/urbackup/ so my configuration will differ from yours but the proxy section should be similar. My apache.conf structure is debian style but an important section of my configuration is:
/etc/apache2/conf-enabled/urbackup.conf
# UrBackup configuration file for apache 2.4 or later
<IfModule mod_alias.c>
Alias /urbackup /usr/share/urbackup/www
</IfModule>
<Directory "/usr/share/urbackup/www">
<IfModule mod_authz_host.c>
Require local
Require ip 192.168.0.0/24
# Replace the range above with your subnet range and add
# other ranges required. I don't make the site available globally.
</IfModule>
</Directory>
<IfModule mod_proxy_fcgi.c>
ProxyPass "/urbackup/x" "fcgi://127.0.0.1:55413"
</IfModule>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
This needs mod_alias, mod_authz_host and mod_proxy_fcgi enabled.
Or if you just want to get rid of welcome page, check welcome.conf in your apache configuration directory!
To make urbackup accessible, you still need to configure your proxy, to access to the urbackup, according to documentation! https://www.urbackup.org/administration_manual.html, 4.2 Make webinterface accessible via SSL
Ok, so because I have messed appache configuration at first I was still getting that welcome page, so removed apache, as I need it only for this proxy thing and reinstalled it, created file with your suggested configuration
/etc/httpd/conf.d/urbackup.conf
And now I`m getting error on the browser:
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
But actually if I open it with default :55413 port it works, any ideas?
I don’t remember the details of getting my setup going but I believe I based it all on 4.2.1 Apache configuration in the administration manual for UrBackup.
I assume that is a general “I can’t connect to the proxied service” message from Apache so the problem will be some detail of the cgi reverse proxy installation. There may be more clues available in Apache logs.
You will need the required Apache modules correctly installed with their prerequisites which caused me some confusion finding which Debian packages were needed. I can’t help with the CentOS setup steps required for a valid Apache cgi reverse proxy.
