Way to use more cores on linux client?
Hi there, im getting ok performance from a linux client, 120mbits or so. seems like the client is CPU limited. On my test rig, i have assigned 4 cores and lots of ram. loaded up some big files and installed the client.
even with the background priority option unchecked in the server, the linux client is only using one core, but it is maxxing out that one core.
Is there a way to tune it so i can get some better transfer speeds from linux clients? the windows clients seem to multithread ok, getting 200ish mbits.
Looks like even on one core, if i turn off compression, i can hit upwards of 500mbit. still tho, curious how to make it multi-threaded.
