Want to reinstall linux client using terminal method - What is the command?
Hi
I’m testing the linux client on a test VM.
I have fully removed the client and want to reinstall it.
I know I can download the .sh package, but I was wondering if there is a way I can see the ‘instruction’ install page again, for an existing client so that I can copy & paste the commands?
It is the page that comes up after adding an Internet client in the Web UI.
I forgot to save that page.
As a test I created a dummy client and see there are 2 identifiers in the install from terminal option:
  1. clientid
  2. authkey
I can see the authkey value of my existing client in the Client settings page, but I cannot find how I can tell what the clientid should be.
Any help is appreciated.
Thank you
