vss_e_object_not_found
I’m running UrBackup Client 2.0.29 on Win 7 (64 bit) & enabled internet mode due to VLAN environment.
Although at the server backup status page appear this err, I don’t have problem with image full/incremantal backup.
(err_cannot_create_symbolic_links). The operation completed successfully. (code: 0)
But I don’t have problem to backup full/incremental image.
I only have problem with full/incremental file backup which are never successful until now with below error:
Starting full file backup…
backupcom->AddToSnapshotSet(&(Server->ConvertToWchar(wpath)[0]), GUID_NULL, &dir->ref->ssetid) failed. VSS error code VSS_E_OBJECT_NOT_FOUND
Creating snapshot of “UrBackup” failed.
Indexing of “UrBackup” done. 1 filesystem lookups 0 db lookups and 0 db updates
emjoshuaTLaptop: Loading file list…
emjoshuaTLaptop: Started loading files…
Waiting for file transfers…
Referencing snapshot on “emjoshuaTLaptop” for path “UrBackup” failed: FAILED
Waiting for file hashing and copying threads…
Saving file metadata…
Writing new file list…
All metadata was present
Transferred 1.97266 KB - Average speed: 15.432 KBit/s
(Before compression: 1.59082 KB ratio: 0.806436)
Time taken for backing up client emjoshuaTLaptop: 2m
Backup completed with issues
I already checked everything about VSS but found nothing wrong. Could anyone assist on this?
What is the path you are trying to backup?
After installed client, it prompted me to select the type of backup. I select to backup user document, desktop, music & video folders.
I gave this value.
Excluded files:
C:\ProgramData\Microsoft\Windows\WER*;C:\windows\Minidump*;:\hiberfil.sys;C:\windows\system32\MSDtc\MSDTC.LOG;C:\windows\softwaredistribution*.;C:\windows\netlogon.chg;:\System Volume Information\MountPointManagerRemoteDatabase;:\Pagefile.sys;C:\Users\JOSHUA~1\AppData\Local\Temp*;C:\windows\system32\LogFiles\WMI\RtBackup:.:;C:\ProgramData\Microsoft\RAC:;:\System Volume Information*{3808876B-C176-4e48-B7AE-04046E6CC752};:\System Volume Information:.{7cc467ef-6865-4831-853f-2a4817fd1bca}DB;:\System Volume Information:.{7cc467ef-6865-4831-853f-2a4817fd1bca}ALT;:\System Volume Information\FVE.{e40ad34d-dae9-4bc7-95bd-b16218c10f72}.:;:\System Volume Information\FVE.{c9ca54a3-6983-46b7-8684-a7e5e23499e3};:\System Volume Information\FVE.{9ef82dfa-1239-4a30-83e6-3b3e9b8fed08};C:\Users\joshuateoh\index.dat;C:\ProgramData\Microsoft\Network\Downloader:;C:\windows\System32\Bits.log;C:\windows\System32\Bits.bak;C:\windows\CSC*;C:\Users\A\index.dat;C:\Users\Administrator\index.dat;C:\Users\emitadmins\index.dat;C:\Users:\AppData\Local\Temp;C:\Users:\AppData\Local\Microsoft\Windows\Temporary Internet Files;C:\Users:\AppData\Local\Google\Chrome\User Data\Default\Cache;C:\Users:\AppData\Local\Google\Chrome\User Data\Default\Media Cache;C:\Users:\AppData\Local\Microsoft\Windows\Explorer\thumbcache;C:\Users:\AppData\Local\Mozilla\Firefox\Profiles:\cache2;C:\Users:\AppData\Local\Mozilla\Firefox\Profiles:\cache;C:\Windows\Temp;:$Recycle.Bin;:\System Volume Information
Included files:
C:\Users:\Documents;C:\Users:\Pictures;C:\Users:\Music;C:\Users:\Videos;C:\Users:\Desktop
I have no problem with image full/incremantal backup. Just only file backup give me problem.
