In UrBackup Infscape Appliance, how can I set up a network card with multiple VLANs so that the settings are not overwritten in the event of an upgrade?
Best regards,
Paul
Best regards,
Paul
Sorry for the late answer.
Coud you post a bit more details on how you setup the VLANs ? E.g. /etc/network/interfaces ? That file should be preserved during update.
In general you can create an executable file at /var/urbackup/post-system-update.local and that one will be executed after system update (touch /var/urbackup/post-system-update.local && chmod +x /var/urbackup/post-system-update.local).
