I am trying to restore a vhdz backup in Windows HyperV server.
I found the topic how to decompress the file - from the bat file located at Program Files -> UrBackup Server folder.
Question is - after the vhdz is decompressed, is it store in the same folder and does it replace the vhdz file with vhd?
After the decompression procedure - the vhdz become around 10GB and it was with the same extenstion. I think it should become 100 GB with vhd as extenstion.
Here is screenshot of the files I am trying to restore, should I use only the Image-C, and do I need the second vhdz file as well?
https://s23.postimg.org/hbgg6cygr/1212.png
Can someone explain to me what the other hash and mbr files are doing and what for they are used?
Thank you!
