I read the following in the manual …
If the server is not configured to distribute the client with CBT, it will not update clients
where the client with CBT was installed manually. Those clients then have to be updated
manually or via some other method.
I would like to know the specific spots I should look to verify that …
1). The server is setup to automatically update ALL clients to the latest version
2). Will the CBT version of the client be automatically pushed to ALL clients once configured after purchase? Yes, I understand you must have a license for each machine, but I’m just asking if the server will STOP pushing the CBT client as an update if your license key only allows for N machines or does it just push a client out regardless of the license situation. I’m asking this for logistical reasons, so I know whether t purchase in mass for ALL current and FUTURE client capacity.
How can I check this?
Is this server-wide, group-wide, client by client?
Thank you for all your help.
P.S. Does the main “Status” page have a column for “VERSION” so I can audit whether each lient has CBT or not?
