this seem to be very buggy at the moment, all sql databases are selected on the server by default which is annoying and often my changes in the components setting dialog have no effect. I check the DB’s I want several times and the selections revert to all databases.
equally even after the settings are seemingly applied something always seems to reset them back to all DB’s after a few days (might be when the server reboots or service restarts now sure)
anyone else using for this and had issues?
should i avoid?
