I’m new to this software. Anyone encountered this issue? False positive?
File : UrBackup Server 2.1.20
Thanks.
Thanks.
Hi
I guess so , it s only 1/67 antivirus who consider this an issue and baidu isn’t well known as an antivirus company.
Had the same problem with kaspersky Internet security (18.0.0.405g, virus data files 2018-03-04 09:51) today with the file UrBackup Server 2.2.8.exe…
KIS log:
04.03.2018 14.52.12 | Le logiciel malveillant a été supprimé. | PDM:Trojan.Win32.Generic | Nom de l’application: C:\Program Files\UrBackupServer\urbackup_srv.exe | Chemin d’accès à l’application: c:\program files\urbackupserver\urbackup_srv.exe | Date et heure: 2018-03-04 14:52 |
04.03.2018 14.52.03 | Le logiciel malveillant a été supprimé. | PDM:Trojan.Win32.Generic | Nom de l’application: C:\Program Files\UrBackupServer\urbackup_srv.exe | Chemin d’accès à l’application: HKLM\System\ControlSet001\Services\UrBackupWinServer\UrBackupWinServer | Date et heure: 2018-03-04 14:52 |
04.03.2018 14.51.34 | Un programme malveillant a été détecté. | PDM:Trojan.Win32.Generic | Nom de l’application: C:\Program Files\UrBackupServer\urbackup_srv.exe | Chemin d’accès à l’application: c:\program files\urbackupserver\urbackup_srv.exe | Date et heure: 2018-03-04 14:51 |
uninstall kasper
Not really a solution !!!
If you don’t trust it, I’d suggest downloading the source code, checking it, then compiling it yourself.
It’s more than 200 000 lines of code. It has a few dependencies, I’d suggest checking them too. Shouldn’t be more than a million lines of code combined
If you suspect a false positive, check the file or the website using Kaspersky VirusDesk. If necessary, send the file to the Antivirus Lab for further analysis.
Result :
The link https://hndl.urbackup.org/Server/2.2.8/UrBack… is safe.
Probably a false positive. I reinstalled this morning (KIS virus data files being updated) and no problem.
My initial post was not to discredite URBackup but just to let know that it has happened.
Thanks you all for your answers.
