Location B ist connected to location A via VPN over a slow internet connection. Due to the VPN connection, the server is recognised as a local server. I can’t use an internet server, because of the lacking IPv6 capability of Urbackup (vote here: Does UrBackup offer ipv6 support?).
Starting an incremental file backup on client B results in the start of a full file backup which should take 4 weeks. Somehow it does not recognize the seed.
So my questions are:
Are there any settings that I need to change for local client B?
Hi.
There s a way to set the client as internet only :
On windows there should be a script to run that enable this mode in program files.
All it does is edit the backend start parameters, so on linux you way as well edit the service conf.
