I have trouble accessing the server using Firefox on Linux.
All I get is the black header with the logo. No login fields.
The following output is in the debug console, but I don’t know if it’s the actual cause:
This page uses the non standard property “zoom”. Consider using calc() in the relevant property values, or using “transform” along with “transform-origin: 0 0”. [192.168.68.122:55414](http://192.168.68.122:55414/)
Source map error: Error: request failed with status 404 Resource URL: http://192.168.68.122:55414/css/bootstrap.chash-2f624089c65f12185e79925bc5a7fc42.min.css Source Map URL: bootstrap.min.css.map
(note that when I copy the url from the error message in a new tab, it loads correctly)
I have Firefox 86.0 on Ubuntu 18.04.
It works when I use Chrome on Linux and also when I use Firefox on Android.
What may be the problem??
Best regards,
Vic
Sorry, this can be wasted… After a reboot of the server I am now able to access it from from Firefox as well. Must have been a temporary hick-up…
This is not a big deal as I have a workaround, but I have encountered the same issue as vimortelmans’ with the similar warnings/errors.
I just upgraded my Ubuntu server from 16.04 to 18.04 which is where my UrBackup server is running. I try to access the GUI via Firefox and only the header and footer load with a loading progress bar going across the screen at the top and the mouse turns into a spinney wheel when I hover over the contents of the page.
I get similar warnings/errors on the same js file as vimortelmans above plus another file when I access from Firefox (version 95.0) from a Windows 10 (version 20H2) machine. The GUI works fine from Chrome (Version 96.0.4664.93).
To see if it is a OS issue, I also tried on Android (version 11) via Firefox (version 94.1.2) and Chrome and again only Chrome works. Seems to be a browser compatibility issue with the login screen.
Also tried updating the Ubuntu server and was able to get to the following Apache versions:
apache2-data (2.4.29-1ubuntu4.20)
apache2-utils (2.4.29-1ubuntu4.20)
apache2-bin (2.4.29-1ubuntu4.20)
apache2 (2.4.29-1ubuntu4.20)
Here are the warning/errors I get on Firefox:
This page uses the non standard property “zoom”. Consider using calc() in the relevant property values, or using “transform” along with “transform-origin: 0 0”. urbackup
Resource URL: https://192.168.0.5/urbackup/js/bootstrap-select.chash-76ee99405563373864c57f9093c526eb.min.js
Source Map URL: bootstrap-select.js.map
Resource URL: https://192.168.0.5/urbackup/js/vs/loader.chash-7bbdd9ad3da370f14fe85315b79133b3.js
Source Map URL: …/…/min-maps/vs/loader.js.map
Resource URL: https://192.168.0.5/urbackup/css/bootstrap.chash-2f624089c65f12185e79925bc5a7fc42.min.css
The errors from Chrome:
DevTools failed to load source map: Could not load content for http://192.168.0.5/urbackup/js/bootstrap-select.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for http://192.168.0.5/urbackup/min-maps/vs/loader.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for http://192.168.0.5/urbackup/css/bootstrap.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for http://192.168.0.5/urbackup/css/bootstrap-theme.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
