I have a windows system image, capacity 25 GB. the image on a network share. I download urbackup restore 1.1.1 but I do not know the restoration steps.
Please, I need help urgently and all stages step by step.
Thank you in advance.
- Take the machine you need to image.
- Place the disc into the tray (USB into the slot), and boot from it.
- Step-by-Step guide through the disc should give you what you want.
I’ll tell you now, when it starts just leave it for a day. If it freezes, don’t assume it failed; mine froze up at 21%, but after I powered it off then back on after a day it worked perfectly.
