Do you mean, you are using urbackup on a machine that has the data mounted from NAS using SMB like \\server\share? Vss is not supported on mounted SMB shares, and Urbackup will complain about it but should do the backup nevertheless.
What do you mean by backup criteria?
Those are normal files, excels, pdfs.
I put UNC paths both in includes and backup paths.
Still gives me the same error, goes directly to idle.
This time I also manually worked on windows search indexing, made sure it was working as service, cleared up old installations on the client and folders on web server.
Started anew, but still nothing.
Do you think maybe it’s because my type of NAS is not supported?
It’s a CTERA, not a NAS Synology
It’s working!!
Nice, thanks to your suggestions, I removed some paths and includes, then I checked the log in debugging mode, removed encrypted transfer via internet, it’s doing its job.
Only thing, seems like it’s capped at 1mbit per second, is there a maximum bitrate cap?
On the UrBackup server there are several settings for clients, many of those are about speed limit.
Just don’t leave them blank, fill them with the speed you like, for example i put 200000 kbps on the backup internet speed section.
After that you can check the speed in the activity tab.
Only thing, after the “files has been transferred” my backup fails and there’s no files on my webserver…
