UrBackup Server 2.0.36.
I’ve had this set up running for a couple of months without any issues. Yesterday I ran upgrades to the OS and rebooted.
Since then, a message has appeared at the top-left of the status screen:
I have UrBackup running on a container within Proxmox on a BTRFS volume. I’ve run a number of commands to verify the used and free space on the drive and everything tells me that there isn’t an issue.
There are two important volumes here, /backup (btrfs) which holds the backup storage and /backupmeta (ext4) which holds the meta data for the backups.
/backup is made up of two disks.
From within the container (Ubuntu 16.04):
$ df -h Filesystem Size Used Avail Use% Mounted on /dev/loop0 20G 2.3G 17G 12% / /dev/mapper/backup_meta-vm--100--disk--1 246G 31G 204G 13% /backupmeta none 492K 0 492K 0% /dev /dev/sdc1 7.3T 2.4T 4.9T 33% /backup tmpfs 16G 0 16G 0% /dev/shm tmpfs 16G 8.3M 16G 1% /run tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 16G 0 16G 0% /sys/fs/cgroup tmpfs 3.2G 0 3.2G 0% /run/user/2001
$ sudo btrfs fi usage /backup Overall: Device size: 7.28TiB Device allocated: 2.44TiB Device unallocated: 4.84TiB Device missing: 7.28TiB Used: 2.38TiB Free (estimated): 4.84TiB (min: 2.42TiB) Data ratio: 1.00 Metadata ratio: 2.00 Global reserve: 512.00MiB (used: 0.00B)
Data,RAID0: Size:2.16TiB, Used:2.16TiB /dev/sdc1 1.08TiB /dev/sdd1 1.08TiB
Metadata,RAID1: Size:139.00GiB, Used:109.75GiB /dev/sdc1 139.00GiB /dev/sdd1 139.00GiB
System,RAID1: Size:8.00MiB, Used:192.00KiB /dev/sdc1 8.00MiB /dev/sdd1 8.00MiB
Unallocated: /dev/sdc1 2.42TiB /dev/sdd1 2.42TiB
The global soft filesystem quota is set to 80%, so that shouldn’t be the issue here either. I’m at a loss - can anyone help?
