Which browser are you using?
Hello
Can you add an inode check,
and add the inode as check in Global soft filesystem quota: ?
Chromium Version 57.0.2950.0 (64-bit) / Windows 7
Cannot reproduce with Chrome either⊠could you have a look in the network tab in the Chrome developer tools if the server returns the archive settings and they then do not get displayed?
Youâll have to look at the network tab
Could you run
SELECT * FROM settings WHERE key=âgroup_idâ AND clientid=0;
on backup_server_settings.db ?
sqlite> SELECT * FROM settings WHERE key='group_id' AND clientid=0;
key value clientid
group_id 1 0
sqlite>
Ok, idk how that got there. It should work after you delete it. I will try to ignore such a setting.
sqlite> delete from settings WHERE key='group_id' AND clientid=0;
sqlite>
Works fine after deleting, thanks !
BTW, is it normal that âFull image backupâ becomes âImage backupâ after saving the rule ?
Regards,
Weâre testing UrBackup with ZFS backend on Debian 8 and got some problems with ZFS backend and âurbackupsrv remove-unknownâ comand :
root@urbackup-3:~# urbackupsrv remove-unknown
2016-12-19 15:01:17: Going to remove all unknown files and directories in the urbackup storage directory. Waiting 20 seconds...
2016-12-19 15:01:37: Shutting down all database instances...
2016-12-19 15:01:37: Opening urbackup server database...
2016-12-19 15:01:37: Testing if backup destination can handle subvolumes and snapshots...
Testing for btrfs...
ERROR: not a btrfs filesystem: /media/backups/testA54hj5luZtlorr494
Testing for zfs...
mount: only root can use "--options" option
cannot mount 'backups/images/testA54hj5luZtlorr494': Invalid argument
filesystem successfully created, but not mounted
TEST FAILED: Creating test zfs volume "backups/images/testA54hj5luZtlorr494" failed
2016-12-19 15:01:48: Waiting for backup destination to support snapshots...
Testing for zfs...
ZFS TEST OK
2016-12-19 15:01:48: Backup destination does handle subvolumes and snapshots. Snapshots enabled for image backups.
2016-12-19 15:01:48: Cleaning up 0 percent
2016-12-19 15:01:48: Cleaning up 0 bytes on backup storage
2016-12-19 15:01:48: Database cache size is 200 MB
2016-12-19 15:01:48: Starting cleanup...
2016-12-19 15:01:48: Freeing database connections...
2016-12-19 15:01:48: Deleting incomplete image file "/media/backups/SVIMPORT/161219-1418_Image_E/Image_E_161219-1418.raw"...
umount: only root can use "--types" option
cannot unmount '/media/backups/images/SVIMPORT/161219-1418_Image_E': umount failed
2016-12-19 15:01:48: WARNING: Deleting incomplete image "/media/backups/SVIMPORT/161219-1418_Image_E/Image_E_161219-1418.raw" failed.
2016-12-19 15:01:48: Deleting incomplete image file "/media/backups/SVIMPORT/161219-1418_Image_F/Image_F_161219-1418.raw"...
cannot unmount '/media/backups/images/SVIMPORT/161219-1418_Image_F': umount failed
2016-12-19 15:01:49: WARNING: Deleting incomplete image "/media/backups/SVIMPORT/161219-1418_Image_F/Image_F_161219-1418.raw" failed.
2016-12-19 15:01:49: Deleting incomplete image file "/media/backups/SVIMPORT/161219-1418_Image_SYSVOL/Image_SYSVOL_161219-1418.raw"...
cannot unmount '/media/backups/images/SVIMPORT/161219-1418_Image_SYSVOL': umount failed
2016-12-19 15:01:49: WARNING: Deleting incomplete image "/media/backups/SVIMPORT/161219-1418_Image_SYSVOL/Image_SYSVOL_161219-1418.raw" failed.
2016-12-19 15:01:49: Deleting incomplete image file "/media/backups/SVIMPORT/161219-1419_Image_C/Image_C_161219-1419.raw"...
cannot unmount '/media/backups/images/SVIMPORT/161219-1419_Image_C': umount failed
2016-12-19 15:01:49: WARNING: Deleting incomplete image "/media/backups/SVIMPORT/161219-1419_Image_C/Image_C_161219-1419.raw" failed.
2016-12-19 15:01:49: Deleting incomplete image file "/media/backups/SVIMPORT/161219-1453_Image_E/Image_E_161219-1453.raw"...
cannot unmount '/media/backups/images/SVIMPORT/161219-1453_Image_E': umount failed
2016-12-19 15:01:49: WARNING: Deleting incomplete image "/media/backups/SVIMPORT/161219-1453_Image_E/Image_E_161219-1453.raw" failed.
2016-12-19 15:01:49: Deleting incomplete image file "/media/backups/SVIMPORT/161219-1453_Image_F/Image_F_161219-1453.raw"...
cannot unmount '/media/backups/images/SVIMPORT/161219-1453_Image_F': umount failed
2016-12-19 15:01:49: WARNING: Deleting incomplete image "/media/backups/SVIMPORT/161219-1453_Image_F/Image_F_161219-1453.raw" failed.
2016-12-19 15:01:49: Deleting incomplete image file "/media/backups/SVIMPORT/161219-1453_Image_SYSVOL/Image_SYSVOL_161219-1453.raw"...
cannot unmount '/media/backups/images/SVIMPORT/161219-1453_Image_SYSVOL': umount failed
2016-12-19 15:01:50: WARNING: Deleting incomplete image "/media/backups/SVIMPORT/161219-1453_Image_SYSVOL/Image_SYSVOL_161219-1453.raw" failed.
2016-12-19 15:01:50: Deleting incomplete image file "/media/backups/SVIMPORT/161219-1454_Image_C/Image_C_161219-1454.raw"...
cannot unmount '/media/backups/images/SVIMPORT/161219-1454_Image_C': umount failed
2016-12-19 15:01:50: WARNING: Deleting incomplete image "/media/backups/SVIMPORT/161219-1454_Image_C/Image_C_161219-1454.raw" failed.
2016-12-19 15:01:50: Enough free space now.
2016-12-19 15:01:50: Deleting old logs...
2016-12-19 15:01:50: Done deleting old logs
2016-12-19 15:01:50: Cleaning history...
2016-12-19 15:01:50: Rewriting daily history...
2016-12-19 15:01:50: Reading history...
2016-12-19 15:01:50: 1 history items read
2016-12-19 15:01:50: Deleting history...
2016-12-19 15:01:50: Writing history...
2016-12-19 15:01:50: Rewriting monthly history...
2016-12-19 15:01:50: 0 history items read
2016-12-19 15:01:50: Rewriting yearly history...
2016-12-19 15:01:50: Done cleaning history
2016-12-19 15:01:50: Cleaning deleted backups history...
2016-12-19 15:01:50: Done cleaning deleted backups history.
2016-12-19 15:01:50: Cleaning up client lists...
2016-12-19 15:01:50: Done cleaning up client lists.
2016-12-19 15:01:50: Updating statistics...
2016-12-19 15:01:50: Updating image stats...
2016-12-19 15:01:50: Updating file statistics...
2016-12-19 15:01:50: Done updating statistics.
2016-12-19 15:01:50: Cleanup successfull.
2016-12-19 15:01:50: Removing unknown for client "SVIMPORT"
2016-12-19 15:01:50: ERROR: Cannot open "/media/backups/SVIMPORT/161219-1351_Image_E": No such file or directory (2)
cannot open 'backups/images/SVIMPORT/161219-1351_Image_E': dataset does not exist
2016-12-19 15:01:50: ERROR: Cannot open "/media/backups/SVIMPORT/161219-1351_Image_F": No such file or directory (2)
cannot open 'backups/images/SVIMPORT/161219-1351_Image_F': dataset does not exist
2016-12-19 15:01:50: ERROR: Cannot open "/media/backups/SVIMPORT/161219-1351_Image_SYSVOL": No such file or directory (2)
cannot open 'backups/images/SVIMPORT/161219-1351_Image_SYSVOL': dataset does not exist
2016-12-19 15:01:50: ERROR: Cannot open "/media/backups/SVIMPORT/161219-1352_Image_C": No such file or directory (2)
cannot open 'backups/images/SVIMPORT/161219-1352_Image_C': dataset does not exist
2016-12-19 15:01:50: ERROR: Cannot open "/media/backups/SVIMPORT/161219-1352_Image_E": No such file or directory (2)
cannot open 'backups/images/SVIMPORT/161219-1352_Image_E': dataset does not exist
2016-12-19 15:01:50: ERROR: Cannot open "/media/backups/SVIMPORT/161219-1353_Image_C": No such file or directory (2)
cannot open 'backups/images/SVIMPORT/161219-1353_Image_C': dataset does not exist
2016-12-19 15:01:50: ERROR: Cannot open "/media/backups/SVIMPORT/161219-1353_Image_F": No such file or directory (2)
cannot open 'backups/images/SVIMPORT/161219-1353_Image_F': dataset does not exist
2016-12-19 15:01:50: ERROR: Cannot open "/media/backups/SVIMPORT/161219-1353_Image_SYSVOL": No such file or directory (2)
cannot open 'backups/images/SVIMPORT/161219-1353_Image_SYSVOL': dataset does not exist
2016-12-19 15:01:50: WARNING: Image backup "161219-1418_Image_E" of client "SVIMPORT" not found in database. Deleting it.
2016-12-19 15:01:50: WARNING: Image backup "161219-1418_Image_F" of client "SVIMPORT" not found in database. Deleting it.
2016-12-19 15:01:50: WARNING: Image backup "161219-1418_Image_SYSVOL" of client "SVIMPORT" not found in database. Deleting it.
2016-12-19 15:01:50: WARNING: Image backup "161219-1453_Image_E" of client "SVIMPORT" not found in database. Deleting it.
2016-12-19 15:01:50: WARNING: Image backup "161219-1453_Image_F" of client "SVIMPORT" not found in database. Deleting it.
2016-12-19 15:01:50: WARNING: Image backup "161219-1453_Image_SYSVOL" of client "SVIMPORT" not found in database. Deleting it.
2016-12-19 15:01:50: Removing dangling file entries...
2016-12-19 15:01:50: Deleted 0 file entries
2016-12-19 15:01:50: Successfully removed all unknown files in backup directory.
Snapshot test :
root@urbackup-3:~# urbackup_snapshot_helper test
Testing for zfs...
ZFS TEST OK
root@urbackup-3:~#
Config
root@urbackup-3:~# uname -a
Linux urbackup-3 4.7.0-0.bpo.1-amd64 #1 SMP Debian 4.7.8-1~bpo8+1 (2016-10-19) x86_64 GNU/Linux
root@urbackup-3:~# cat /etc/urbackup/dataset
backups/images
root@urbackup-3:~# cat /etc/urbackup/backupfolder
/media/backups
root@urbackup-3:~# mount
backups on /media/backups type zfs (rw,relatime,xattr,noacl)
backups/images on /media/backups/images type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT on /media/backups/images/SVIMPORT type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT/161219-1418_Image_E on /media/backups/images/SVIMPORT/161219-1418_Image_E type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT/161219-1418_Image_F on /media/backups/images/SVIMPORT/161219-1418_Image_F type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT/161219-1418_Image_SYSVOL on /media/backups/images/SVIMPORT/161219-1418_Image_SYSVOL type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT/161219-1419_Image_C on /media/backups/images/SVIMPORT/161219-1419_Image_C type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT/161219-1453_Image_E on /media/backups/images/SVIMPORT/161219-1453_Image_E type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT/161219-1453_Image_F on /media/backups/images/SVIMPORT/161219-1453_Image_F type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT/161219-1453_Image_SYSVOL on /media/backups/images/SVIMPORT/161219-1453_Image_SYSVOL type zfs (rw,relatime,xattr,noacl)
backups/images/SVIMPORT/161219-1454_Image_C on /media/backups/images/SVIMPORT/161219-1454_Image_C type zfs (rw,relatime,xattr,noacl)
root@urbackup-3:~# ps faxu | grep urbackup
root 6954 1.0 3.8 1377920 39584 ? Sl 14:17 0:31 /usr/bin/urbackupsrv run -u root --config /etc/default/urbackupsrv --daemon --pidfile /var/run/urbackupsrv.pid
root@urbackup-3:~# cat /var/urbackup/backupfolder
/media/backups
root@urbackup-3:~# ls -l /media/backups/
total 26
drwxr-x--- 2 root root 2 déc. 19 13:31 clients
drwxr-xr-x 3 root root 3 déc. 19 15:01 images
drwxr-x--- 2 root root 18 déc. 19 14:54 SVIMPORT
drwxr-x--- 2 root root 15 déc. 19 13:52 urbackup
drwxr-x--- 2 root root 2 déc. 19 14:17 urbackup_tmp_files
root@urbackup-3:~#
Any ideas ?
Regards,
Youâll need to run everything with -u root, i.e. urbackupsrv remove-unkown -u root
Thanks. I thought that running the command as root was enough âŠ
