Uroni - if symlinks are only for file backups, and a user is only doing image backups, then maybe you can suppress the message if it doesn’t affect them?
2016-05-25 11:16:08: Connecting to target service...
2016-05-25 11:16:08: Established internet connection. Service=0
2016-05-25 11:16:08: Scanning for changed hard links on volume of "Users"...
2016-05-25 11:16:08: Following symbolic link at "C:\Users\All Users" to "C:\ProgramData" confirms symlink backup target ".symlink_ProgramData" to "C:\ProgramData"
2016-05-25 11:16:08: Indexing of "Users" done. 21 filesystem lookups 353 db lookups and 15 db updates
2016-05-25 11:16:08: CLIENTEXT-7: Doing backup with hashed transfer...
2016-05-25 11:16:08: CLIENTEXT-7: Connecting to client...
2016-05-25 11:16:08: Authed+capa for client 'CLIENTEXT-7' (token auth) - 1 spare connections
2016-05-25 11:16:08: Established internet connection. Service=1
2016-05-25 11:16:09: Authed+capa for client 'CLIENTEXT-7' (token auth) - 1 spare connections
2016-05-25 11:16:09: Connecting to target service...
2016-05-25 11:16:09: Established internet connection. Service=1
2016-05-25 11:16:09: CLIENTEXT-7: Loading file list...
2016-05-25 11:16:09: Flushing FileClient...
2016-05-25 11:16:10: CLIENTEXT-7 Starting incremental backup...
2016-05-25 11:16:10: CLIENTEXT-7: Calculating file tree differences...
2016-05-25 11:16:10: CLIENTEXT-7: Creating snapshot...
2016-05-25 11:16:10: Flushing FileClient...
2016-05-25 11:16:10: CLIENTEXT-7: Deleting files in snapshot... (51)
2016-05-25 11:16:11: CLIENTEXT-7: Deleting files in hash snapshot...
2016-05-25 11:16:11: Connecting to target service...
2016-05-25 11:16:11: Established internet connection. Service=1
2016-05-25 11:16:11: Flushing FileClient...
2016-05-25 11:16:11: CLIENTEXT-7: Calculating tree difference size...
2016-05-25 11:16:11: CLIENTEXT-7: Linking unchanged and loading new files...
Webui “show logs” output :
25/05/16 11:39 DEBUG Reflink copying is enabled
25/05/16 11:39 INFO Starting incremental file backup...
25/05/16 11:39 DEBUG CLIENTEXT-7: Doing backup with hashes...
25/05/16 11:39 DEBUG CLIENTEXT-7: Doing backup with intra file diffs...
25/05/16 11:39 DEBUG CLIENTEXT-7: Connecting for filelist...
25/05/16 11:39 DEBUG CLIENTEXT-7: Waiting for filelist
25/05/16 11:41 INFO Scanning for changed hard links on volume of "Users"...
25/05/16 11:41 INFO Following symbolic link at "C:\Users\All Users" to "C:\ProgramData" confirms symlink backup target ".symlink_ProgramData" to "C:\ProgramData"
25/05/16 11:41 INFO Indexing of "Users" done. 8 filesystem lookups 366 db lookups and 7 db updates
25/05/16 11:41 DEBUG CLIENTEXT-7: Doing backup with hashed transfer...
25/05/16 11:41 INFO CLIENTEXT-7: Loading file list...
25/05/16 11:41 DEBUG CLIENTEXT-7 Starting incremental backup...
25/05/16 11:41 INFO CLIENTEXT-7: Calculating file tree differences...
25/05/16 11:41 INFO CLIENTEXT-7: Creating snapshot...
25/05/16 11:41 INFO CLIENTEXT-7: Deleting files in snapshot... (52)
25/05/16 11:41 INFO CLIENTEXT-7: Deleting files in hash snapshot...
I try to restart server and launch incremental backup 3 times : same error.
Ok, got it now. Used the wrong command. If your minimal number of incremental file backups for that client is zero the issue should be fixed with the next version.
