Think I fixed it. Will be fixed with server 2.0.14.
Okay i will try with 2.0.14 ASAP.
Thank you very much !
john3354, thanks a lot for the information.
Is there any document regarding the code organization and instructions for compiling the packages? Such a document will be very helpful.
That document could use some improvement, but if you are familiar with Visual Studio and software development, you should be able to muddle through.
@Uroni
Hi
Do you plan to release 2.0.14 soon ?
For information we still have the problem with 2.0.13 Server / 2.0.11 Client this morning :
2016-05-02 23:06:51: WARNING: Read error in hash calculation at position 103079215104 toread=4096 read=0. This will cause the whole block to be loaded. No such file or directory (code: 2)
2016-05-02 23:06:51: ERROR: Chunk not requested. (103079215104)
2016-05-02 23:06:51: ERROR: Pending chunk: 1572864
And server crash with no more informations in server’s logfile (running with --loglevel debug)
Regards,
John3354,
Thanks a lot for the information. Will look into it.
Server’s crash seems to be fixed since i’ve upgraded to 2.0.14 Server / 2.0.12 Client
Thank you very much, you’re the best
I still have some errors messages that i’ve reported in this post UrBackup Server 2.0.13 beta/Client 2.0.11 beta but they are only Warnings, i should still be able to restore files ?
Regards,
