I have everything working until I attempt to restart the container. After the restart of the container I can no longer mount either backup images or file backups. I receive the following LOG.
One point of interest is invalid argument error:
Guestunmount…
guestunmount: failed to unmount /backups/chris-pc9/241109-1404_Image_C_mnt0: fusermount: failed to unmount /backups/chris-pc9/241109-1404_Image_C_mnt0: Invalid argument
and possible permission issue
2024-11-09 16:34:30: ERROR: Error opening Bitmap file “/backups/chris-pc9/241109-1404_Image_C/Image_C_241109-1404.raw.bitmap” for writing
024-11-09 16:33:43: Started UrBackup…
2024-11-09 16:33:43: Removing temporary files…
2024-11-09 16:33:43: Recreating temporary folder…
2024-11-09 16:33:44: InternetService: Server started up successfully!
2024-11-09 16:33:44: UrBackup Server start up complete.
2024-11-09 16:33:44: Looking for old Sessions… 0 sessions
2024-11-09 16:33:44: Server started up successfully!
2024-11-09 16:33:44: Unmounting mounted image backup id 3 partition 0 path “/backups/chris-pc9/241109-1404_Image_C/Image_C_241109-1404.raw” mounted 2m 42s ago
2024-11-09 16:33:44: Backup destination does handle subvolumes and snapshots. Snapshots enabled for image and file backups.
2024-11-09 16:33:44: Emulating reflinks via copying
2024-11-09 16:33:44: Reflink ioctl failed. errno=11
2024-11-09 16:33:44: Broadcasting on ipv4 interface enp2s0 addr 192.168.1.235
2024-11-09 16:33:44: Broadcasting on ipv4 interface br-125dd94be5ed addr 172.16.1.1
2024-11-09 16:33:44: Broadcasting on ipv4 interface docker0 addr 172.16.0.1
2024-11-09 16:33:44: Broadcasting on ipv6 interface enp2s0 addr fe80::6ebf:b5ff:fe02:ee4e
2024-11-09 16:33:44: Broadcasting on ipv6 interface br-125dd94be5ed addr fe80::42:34ff:fe56:5a58
2024-11-09 16:33:44: Broadcasting on ipv6 interface vethe3ef57d addr fe80::20b0:3cff:fe71:182c
2024-11-09 16:33:45: Downloading version file…
2024-11-09 16:33:46: Downloading version file…
2024-11-09 16:33:46: Downloading server version info…
2024-11-09 16:33:47: Downloading dataplan database…
2024-11-09 16:34:15: ERROR: Image mounting failed: Mountpoint: /backups/chris-pc9/241109-1404_Image_C_mnt0
Guestunmount…
USER PID ACCESS COMMAND
root kernel mount /backups
Unmounting “/backups/chris-pc9/241109-1404_Image_C_mnt0” failed.
2024-11-09 16:34:15: ERROR: Unmounting image backup id 3 path “/backups/chris-pc9/241109-1404_Image_C/Image_C_241109-1404.raw” mounted 2m 42s ago failed: Mountpoint: /backups/chris-pc9/241109-1404_Image_C_mnt0
Guestunmount…
2024-11-09 16:34:16: New Backupclient: chris-pc9
2024-11-09 16:34:31: ERROR: Error opening Bitmap file “/backups/chris-pc9/241109-1404_Image_C/Image_C_241109-1404.raw.bitmap” for writing
2024-11-09 16:34:45: ERROR: Cannot open “/backups/chris-pc9/241109-1318”: No such file or directory (2)
2024-11-09 16:34:49: ERROR: Cannot open “/backups/chris-pc9/241109-1318”: No such file or directory (2)
2024-11-09 16:34:53: ERROR: Cannot open “/backups/chris-pc9/241109-1318”: No such file or directory (2)
root@truenas:/var/log#
Here is the docker compose
version: “2”
services:
urbackup:
image: uroni/urbackup-server:latest-zfs
privileged: true
container_name: urbackup
restart: unless-stopped
environment:
- PUID=0 # Enter the UID of the user who should own the files here
- PGID=0 # Enter the GID of the user who should own the files here
- TZ=Australia/… # Enter your timezone
volumes:
- /mnt/tank/docker/urbackup/db:/var/urbackup
- /mnt/tank/docker/urbackup/backups:/backups
- /mnt/tank/docker/urbackup/config:/etc/urbackup
# Uncomment the next line if you want to bind-mount the www-folder
#- /path/to/wwwfolder:/usr/share/urbackup
network_mode: host
# Uncomment the following two lines if you’re using BTRFS support
#cap_add:
# - SYS_ADMIN
# Uncomment the following two lines if you’re using ZFS support
devices:
- /dev/zfs:/dev/zfs
networks:
ix-dockge_default:
external: true
and the file structure
tank/docker/urbackup 473G 3.05T 112K /mnt/tank/docker/urbackup
tank/docker/urbackup/backups 134M 3.05T 134M /mnt/tank/docker/urbackup/backups
tank/docker/urbackup/config 104K 3.05T 104K /mnt/tank/docker/urbackup/config
tank/docker/urbackup/db 193M 3.05T 193M /mnt/tank/docker/urbackup/db
tank/docker/urbackup/files 300G 3.05T 96K /mnt/tank/docker/urbackup/files
tank/docker/urbackup/files/chris-pc9 300G 3.05T 96K /mnt/tank/docker/urbackup/files/chris-pc9
tank/docker/urbackup/files/chris-pc9/241109-1318 300G 3.05T 300G /mnt/tank/docker/urbackup/files/chris-pc9/241109-1318
tank/docker/urbackup/images 173G 3.05T 96K /mnt/tank/docker/urbackup/images
tank/docker/urbackup/images/chris-pc9 173G 3.05T 104K /mnt/tank/docker/urbackup/images/chris-pc9
tank/docker/urbackup/images/chris-pc9/241109-1404_Image_C 172G 3.05T 172G /mnt/tank/docker/urbackup/images/chris-pc9/241109-1404_Image_C
tank/docker/urbackup/images/chris-pc9/241109-1404_Image_ESP 32.7M 3.05T 32.7M /mnt/tank/docker/urbackup/images/chris-pc9/241109-1404_Image_ESP
tank/docker/urbackup/images/chris-pc9/241109-1404_Image_SYSVOL 690M 3.05T 690M /mnt/tank/docker/urbackup/images/chris-pc9/241109-1404_Image_SYSVOL
and storage files
root@truenas:/var/log# cd /etc/urbackup
root@truenas:/etc/urbackup# ls
backupfolder dataset dataset_file
root@truenas:/etc/urbackup# cat backupfolder
/backupsroot@truenas:/etc/urbackup# cat dataset
root@truenas:/etc/urbackup# cat dataset_file
I also have installed libguestfs-tools in the container.
