Good evening,
I want to ask whether is possible to install UrBackup 2.0.x on Synology with CPU MARVELL Kirkwood 88F6281. I found version 1.4.13 on Daniel Tofee web page but the new version is unfortunately not there. Thank you for your wondreful software!
I was succesful at the end
simplyfied steps:
- install Debian Chroot to DMS ( https://synocommunity.com/#easy-install )
- download source codes of urbackup 2.1
- switch to Debian Chroot
- unistall systemd and install sysV ( http://without-systemd.org/wiki/index.php/How_to_remove_systemd_from_a_Debian_jessie/sid_installation )
- finish instalation of the packages for compilation (crypto++, gcc, etc)
- compile urbackup
- use init script from different server
- set startup after the start of synology chroot and init script
Hmm http://packages.synocommunity.com is not available (400 bad request).
With a more modern CPU the ARMv7+ debian package on the download page should work…
I have edited step one.
I have tried instalation from the compiled package but it failed (wrong CPU).
Yeah, your CPU in the first post is a ARMv5 CPU. Those are really old…
Yes I know. I have tried the instalation even for Synology with CPU Intel Atom and there was possible to use a compiled package.
Would it be hard for You to prepare the compiled package for ARMv5, too?
Thanks a lot for Your perfect software anyway!
That way we could run UrBackup on a Palm ![]()
I followed your steps and with small adjustments works as it should, but …, of course always exist a but, when I want to transfer my old server database from ubuntu I get “segmentation fault” error and the urbackup process dye. Is working flawless with the fresh database. Is anybody who have more experience with this?
Web gui (ip_address:55414) stopped working after I upgraded to version 2.1.19. Any suggestion? Backup still works. Thank you!
If anybody is interested in it. I also managed to get the urackup client running on a synlogy NAS.
Here are the steps:
- add new package source: SynoCommunity
- install community/debian chroot
- open ssh connection to nas
- vi /var/packages/debian-chroot/scripts/start-stop-status
- add line after other mounts (assuming you want to backup volume 1):
grep -q "${CHROOTTARGET}/mnt/volume1 " /proc/mounts || mount -o bind /volume1 ${CHROOTTARGET}/mnt/volume1
- add line after other umounts
umount ${CHROOTTARGET}/mnt/volume1
- add to /etc/rc.local
chroot /volume1/@appstore/debian-chroot/var/chroottarget /usr/local/sbin/urbackupclientbackend -d
- /var/packages/debian-chroot/scripts/start-stop-status chroot
- apt-get update && apt-get upgrade
- apt-get install locales
- dpkg-reconfigure locales
- choose en-us-utf8
- install urbackup client from script (see UrBackup - Download UrBackup for Windows, GNU/Linux or FreeBSD)
- in urbackup server gui add new remote client and copy config string and execute on shell (still inside of the chroot)
- urbackupclientctl add-backupdir -d /mnt/volume1
You should be done ![]()
I didn’t try out if the client would work outside of the chroot. maybe it would…
How to run urbackup server inside of chroot ?
You should be fine with a 2.1.20 build of the server. Mind I have not tried it yet , I am running a patched 2.1.19.
The issue is an infinite loop when the server runs on armv5 (no support for accept4) https://github.com/uroni/urbackup_backend/commit/eb4e5ed2a13559ca390a175c438702415ddea6df .
If you want to stick to 2.1.19 you also need https://github.com/uroni/urbackup_backend/commit/3536af43eeee847fb1b5f012fe978604ccebce23. Cheers
