Hi
The gui doesn’t show the mount option when browsing vhd/vhdz
The service run inside a docker
UrBackup Server v2.2.11.2193
when browsing the vhd, a single line appear
VHD-Parent: “/var/docker/data/urbackup-server/datas/urb-client/180403-1246_Image_C/Image_C_180403-1246.vhd”
fuse module has been loaded and urbackup restarted
os is archlinux so the packages depends on fuse and is compilled with -with-mountvh
/usr/sbin/urbackup_mount_helper is setuid
urbackupsrv mount-vhd --file /var/docker/data/urbackup-server/datas/urb-client/180403-1246_Image_C/Image_C_180403-1246.vhd --mountpoint /mnt/tmp/
Loading FUSE kernel module…
modprobe: FATAL: Module fuse not found in directory /lib/modules/4.15.15-1-ARCH
Starting VHD background process…
Waiting for background process to become available…
^C
during that times dmesga and journalctl shows nothing special
ls -l /lib/modules/4.15.15-1-ARCH
ls: impossible d’accéder à ‘/lib/modules/4.15.15-1-ARCH’: nu such file or folder
lsmod | grep fuse
fuse 118784 1
i installed libguestfs (should i ask to add that dependency in the archlinux package ? )
libguestfs-test-tool finished with ===== TEST FINISHED OK =====
/var/log/urbackup-fuse.log contains
2018-04-20 12:27:50: Mounting VHD via fuse…
2018-04-20 12:27:50: Volume offset is 524288 bytes. Configure via --offset
2018-04-20 12:27:50: ERROR: Error mounting fuse filesystem
