I got a system that backups just fine but when i navigate to the actual backups it shows a single a backup which is obviously wrong. Any way to fix this? this seems to be a issue with this one client
Hello
Please can you give more information about your environment, did you made any migration??
Are you using the application installed on the host or it’s in docker??
I am using Portainer on top of TrueNAS in which i use compose.
I have not made any migrations yet.
services:
urbackup:
image: uroni/urbackup-server:latest-zfs
container_name: urbackup
restart: unless-stopped
environment:
- PUID=1000 # Enter the UID of the user who should own the files here
- PGID=100 # Enter the GID of the user who should own the files here
- TZ=Europe/Amsterdam # Enter your timezone
volumes:
- /mnt/CHONK/backups/urbackup/database:/var/urbackup
- /mnt/CHONK/backups/urbackup/backup:/backups
- /mnt/CHONK/backups/urbackup/www:/usr/share/urbackup
# Uncomment the next line if you want to bind-mount the www-folder
#- /path/to/wwwfolder:/usr/share/urbackup
cap_add:
- SYS_NICE
network_mode: "host"
# Uncomment the following two lines if you're using BTRFS support
#cap_add:
# - SYS_ADMIN
# Uncomment the following two lines if you're using ZFS support
devices:
- /dev/zfs:/dev/zfs
Did you check the right PUID and PGID?
Check the permission folders on your host.
