Buzzz
March 4, 2022, 9:47am
1
Good morning,
Since one day, I have this message “UrBackup is currently doing maintenance and is temporarily unavailable.” when I connect to the web interface, and therefore no more backup. I have no way to send the logs through the interface.
here are the urbackup.logs
What is the procedure to restore from the last backup that should be stored on the S3
thank you in advance.
Buzzz
March 4, 2022, 4:19pm
3
The S3 storage is not the problem.
I really need help to understand what is going on.
uroni
March 4, 2022, 6:42pm
4
Here is instructions to recover a local appliance from s3: https://www.infscape.com/wp-content/uploads/2021/03/Recover-from-S3-1.pdf
Do backup your s3 encryption key before resetting the system.
Buzzz
March 4, 2022, 7:54pm
5
Thanks but Where can I find the key because I no longer have access to the interface.
uroni
March 4, 2022, 8:27pm
6
Sorry, you can check at app.urbackup.com or
sudo echo "SELECT value FROM settings WHERE key='clouddrive_settings'" | sqlite3 /var/urbackup/app.db
