Urbackup in Proxmox linux container
Hi, I am trying to install urbackup in a proxmox container so that it backs up to a zpool that I have created in proxmox.
It seemed simple in my head, but I’m having a hard time getting it to work :slight_smile:
I created a raidz2 in proxmox (tank) and then added a bind mount to the urbackup container. This way I can’t use the raw copy option with zfs, container doesn’t detect the zpool.
Is it possible to make a container directly access the zpool created in proxmox?
